September 24, 2026, 04:34:38 am
| | |-+  how do i wire a shift light into my autometer tach?
Author Topic: how do i wire a shift light into my autometer tach?  (Read 4405 times)
beetletom
« on: March 22, 2011, 13:26:21 pm »
is it be possible with this tach, as it doesn't have the buttons on the right side of the face to set the revs??
« Reply #1 on: March 22, 2011, 15:42:17 pm »
Your best bet would be to purchase the shift-light that Autometer sells ... the rpm is set using 'pills' that plug in.
Something like this: http://www.jegs.com/i/Auto+Meter/105/5340/10002/-1
Good luck with it!
TxT
beetletom
« Reply #2 on: March 22, 2011, 16:07:52 pm »
yep ive got an autometer shift light, not a plug in one, but has 2 wires from it.
so looks like if i need to buy the one above, with the plug in pils?
« Last Edit: March 22, 2011, 16:12:43 pm by beetletom » Logged
« Reply #3 on: March 22, 2011, 16:41:54 pm »
Unless you use an MSD, or the like, ignition. They sell an RPM activated switch/relay that will turn on an external accessory ... like your shift-light.
beetletom
« Reply #4 on: March 22, 2011, 16:56:53 pm »
cool thanks!
Kaferdog
« Reply #5 on: March 23, 2011, 07:59:41 am »
I had the same Tach but wanted a shift light also....so I just got this Tach instead.........this way you can set your shift points where ever you want ...anytime !
http://www.autometer.com/cat_gaugedetail.aspx?gid=2909&sid=15
« Last Edit: March 23, 2011, 08:01:56 am by Kaferdog » Logged
