October 01, 2026, 01:52:25 am
| | |-+  48 IDA Repair...?
Author Topic: 48 IDA Repair...?  (Read 6568 times)
Stoo the worm Simpson
« on: March 28, 2011, 12:06:58 pm »
Does anyone know if it is possible to tig weld an IDA, as one of mine has a worn hole where the accelerator pump lever sits in the main body of the carb....
I need to fill this hole up before i can re-drill the hole again,
Or is there any other way this can be achieved...like a pressed in bush etc.
I have circled the part in this rather bad pic...sorry i have know idea why it has come out like this.
Thanks in advance.
Stoo
« Reply #1 on: March 28, 2011, 12:12:40 pm »
Stu, I can't see the pictures at work, but if you have a read through this: http://ultimateaircooled.com/simplemachinesforum/index.php/topic,1795.630.html you'll find some useful info! Page 43 onwards if it goes to the start of the thread!
« Reply #2 on: March 28, 2011, 12:26:11 pm »
Thanks for that mate...ive just registered so i can take a look....i will let you know how i get on.
Thanks again
« Reply #3 on: March 28, 2011, 15:47:10 pm »
Heres another photo as im not sure anyone can see the other one...!
Carsten
« Reply #4 on: April 01, 2011, 13:02:24 pm »
Maybe you do not have to weld it up. I would try to drill it bigger and put a bush in (maybe with glue or press fit). Then put the shaft in.
My idea...
Carsten
1969 IRS bug
« Reply #5 on: April 01, 2011, 13:45:42 pm »
You can't TIG it, too much zink in the casting. Your carb will melt away. I would try the Timesert M3 method or the Helicoil ( Huh).
« Reply #6 on: April 01, 2011, 20:44:40 pm »
I've TIG welded Webers before. It welds just like any other ally casting I've welded.
One non-welding cure is to drill the hole larger, and thread it.  Then get a new steel post custom made with that same thread on it. Loctite and screw it in.
