November 02, 2026, 16:43:09 pm
DDS type power pulley info
Topic: DDS type power pulley info (Read 4818 times)
Fritter
March 29, 2011, 05:32:23 am »
Picked up a DDS or DDS type power pulley last weekend. It measures:
a. 135mm or 5.3" overall diameter. What size fan belt is used for this pulley?
b. 44mm or 1.7" diameter sand seal surface. Is there a modern press in sand seal that can be used for it?
Mike F.
'64 Indigo Blue sunroof Bug
Re: DDS type power pulley info
March 30, 2011, 04:26:22 am »
Go to your local Ford dealer and buy a JB332 fan belt. The OEM to Ford is Gates. This belt is indestructable!
It is 7/16" wide, 33¼" long. Your pulley ratio will be slightly above 1:1.
Fritter
March 30, 2011, 17:24:02 pm »
Thanks Bruce. What do you use for sand seal? Or do you have a non sand seal version.
Mike F.
March 30, 2011, 18:35:10 pm »
March 30, 2011, 18:38:01 pm »
Quote from: Lids on March 30, 2011, 18:35:10 pm
Cool, there you go ... just cut open the package and measrue the belt!
Fritter
March 30, 2011, 18:58:37 pm »
Problem, I see a DDS pulley and an Empi belt! Like fire and water!
Mike F.
March 31, 2011, 04:28:37 am »
Power Pulley Belt
For those with a Power Pulley, you will need a smaller belt.
Brand Part Number Size Metric Conversion
EMPI 9120 9.5mm x 850mm
CB Performance 2047 10 x 865mm
Gene Berg GB 445
Gates 7325 13/32" x 33 1/8" 10.3188 x 841.375mm
Gates 7330 13/32" x 33 5/8" 10.3188 x 854.075mm
Gates 7335 13/32" x 34 1/8" 10.3188 x 866.775mm
March 31, 2011, 05:40:32 am »
Quote from: Mike Fritz on March 30, 2011, 17:24:02 pm
I have a few of those pullies, and all of them are VW style that screw the oil back in. I've never had a leak.
