November 02, 2026, 16:42:31 pm
| | |-+  DDS type power pulley info
Author Topic: DDS type power pulley info  (Read 4816 times)
Fritter
« on: March 29, 2011, 05:32:23 am »
Picked up a DDS or DDS type power pulley last weekend.  It measures:
a.  135mm or 5.3" overall diameter.  What size fan belt is used for this pulley?
b.  44mm or 1.7" diameter sand seal surface.  Is there a modern press in sand seal that can be used for it?
Mike F.
'64 Indigo Blue sunroof Bug
« Reply #1 on: March 30, 2011, 04:26:22 am »
Go to your local Ford dealer and buy a JB332 fan belt.  The OEM to Ford is Gates.  This belt is indestructable!
It is 7/16" wide, 33¼" long.  Your pulley ratio will be slightly above 1:1.
Fritter
« Reply #2 on: March 30, 2011, 17:24:02 pm »
Thanks Bruce. What do you use for sand seal?  Or do you have a non sand seal version.
Mike F.
« Reply #3 on: March 30, 2011, 18:35:10 pm »
Wink
« Reply #4 on: March 30, 2011, 18:38:01 pm »
Wink
Cool, there you go ... just cut open the package and measrue the belt!
 Grin
Fritter
« Reply #5 on: March 30, 2011, 18:58:37 pm »
Problem, I see a DDS pulley and an Empi belt!  Like fire and water!  Cheesy
Mike F.
« Reply #6 on: March 31, 2011, 04:28:37 am »
Power Pulley Belt
For those with a Power Pulley, you will need a smaller belt.
Brand Part Number Size Metric Conversion
EMPI  9120 9.5mm x 850mm
CB Performance 2047 10 x 865mm
Gene Berg GB 445
Gates  7325 13/32" x 33 1/8" 10.3188 x 841.375mm
Gates  7330  13/32" x 33 5/8" 10.3188 x 854.075mm
Gates  7335  13/32" x 34 1/8" 10.3188 x 866.775mm
« Reply #7 on: March 31, 2011, 05:40:32 am »
I have a few of those pullies, and all of them are VW style that screw the oil back in.  I've never had a leak.
