October 13, 2026, 13:46:41 pm
Scat push-pull linkage question
Topic: Scat push-pull linkage question (Read 6056 times)
bugnut68
April 01, 2011, 16:40:55 pm »
I've got the Scat universal push-pull linkage for my new 2017 and I installed it last night. One minor issue, though, I've run into is interference with the pivot and the two rods that go to each carb. The linkage tends to lock open at wide open throttle due to the heim joint of the number 1/2 side interfering with the billet upright block upon which the pivot twists. There were no bushings included in the kit, but it appears I'm going to have to shim the pivot upwards in order to keep this interference from happening... just checking to see if others have had this issue, or if there's something I've overlooked from my installation?
bugnut68
Re: Scat push-pull linkage question
April 01, 2011, 21:08:56 pm »
As an update I read on the Samba that a couple guys had to grind on the brace piece that bolts to the fan shroud in order for the 1/2 side throttle rod to clear, so I guess I found my answer.
youngnstudly
April 02, 2011, 17:45:18 pm »
There's your answer. I had do do the same thing on my scat linkage years ago.
Andy
SlingShot
April 03, 2011, 05:01:26 am »
Just Installed this setup on a customers Kadron setup. Same issue had to do some grinding on the center link brace. Also had to shim the 1-2 arm down to clear the generator stand. The kit has a couple hangups but not to shabby for the price.
Will Race For Beer !!!
bugnut68
April 04, 2011, 21:58:07 pm »
How did you guys mount the spring that comes with the kit? The directions dont' address this, either...
stealth67vw
April 05, 2011, 00:57:02 am »
I drilled a hole in the alternator and used a spring from a 30 Pict-3.
John Bates
JB Machining Services
12.34 @ 108 mph 1/4
7.76 @ 89mph 1/8
April 05, 2011, 02:49:02 am »
To jump on the bandwagon, I notched the support to the shroud on mine. Also think I did some work to the base block, but don't remember exactly what. I think it was to fit to the case better. Otherwise, it works quite well.
April 05, 2011, 10:29:54 am »
i got it fixed on the shroud by opening the support, made a rightwards U instead of the O so to speak.
and i used exactly the same spring as John showed but hooked it up on the lower opening of my generator. the spring was a little too tough, though.
DVK ~
