September 25, 2026, 08:45:01 am
| |-+  For sale!
| | |-+  Berg 5 Speed Street/Strip FTC / IRS Quaife Transmission !!!SOLD!!!
Author Topic: Berg 5 Speed Street/Strip FTC / IRS Quaife Transmission !!!SOLD!!!  (Read 3997 times)
didi
« on: April 03, 2011, 08:23:02 am »
with most berg parts, 0km since build up! everything new if there is no comment.
with all the berg tricks modifications
-handpacked needle bearings for minimun siderock and maximum support for 1st-5th
-steel shift forks
-additional oil hub holes/and gear grooves for minimal gearstack clearance and proper oiling
-3/4th solid gear sleeve
B5S1000 5 Speed Conversion Kit $1647
GB 663D FTC Close Ratio 1st and Second Gear Set 4.11 1st with 2.47 2nd $692
GB650-170H FTC Close Ratio 3rd Gear 1.70 with welded hub $257
GB 652K-131H Close Ratio 4th Gear Set 1.31 with welded hub $250
GB 089 VW good used  5th Gear Set 0.89 with new GB659 welded hub $138
GB 660K-3875 pinion with nut. Klinkenberg design helix angle for maximum strength for street and strip. 3.875:1 ratio. $241
GB 643F Berg mid Rubber mount $245
PRO1000 4 bolt Pinion retainer $92
GB 661-SET Handpacked needle bearing set 1st to 5th $105
GB664 3rd gear sleeve and heat treated thrust washer set $25
GB 667 Hardened woodruff keys 3th/4th gear   $12
New original VW Parts: Pinion Bearing, Diff Bearings, all Synchros, steel shift forks, reverse lever, misc Parts, Screws   $450
Rhino Case   $380
Heavy Duty Side covers   $260
Quaife IRS Differential ATB with T1 Spline $1100
« Last Edit: April 04, 2011, 22:18:04 pm by didi » Logged
Didi - Aircooled VW
http://didivw.blogspot.com/
didi
« Reply #1 on: April 03, 2011, 08:27:40 am »
Didi - Aircooled VW
didi
« Reply #2 on: April 04, 2011, 22:17:26 pm »
sold!!!
Didi - Aircooled VW
