November 03, 2026, 15:54:52 pm
| | |-+  8 Dowell flywheel drilling jig help
Author Topic: 8 Dowell flywheel drilling jig help  (Read 5714 times)
« on: April 03, 2011, 13:23:43 pm »
Ive got a genuine vw 200mm flywheel i am going to get my local machine shop to resurface, lighten and 8 dowell.
Ive bought the drilling jig, butwhat size do I need to ask them to drill the extra 4 holes to (ream)
Its going on a 82mm cb crank if that makes any difference?
Lee
Dougy Dee
« Reply #1 on: April 03, 2011, 18:41:11 pm »
Check the Berg site. They had great instructions including drill and ream sizes for those units, with the ones they sold. Problem is getting the proper crush. I think th next one I do I'll ream the assembly to 5/16 then use an undersized 8mm on the crank to get crush.
Jee Ent.
« Reply #2 on: April 05, 2011, 19:46:37 pm »
I use a 7,9mm drill bit on both the crank and flywheel.
The 8mm dowels will get a tight fit in the crank without any other work. And won't come loose if done right. Remember to slightly countersink the holes before mounting the dowels.
Use a 8mm reamer to finish of the holes in the flywheel. A slight countersink is recommended here also..
Jee
Dr P.
« Reply #3 on: May 13, 2011, 13:55:24 pm »
Second that. I also use a 7,9mm drill to do the 4 extra dowells. I did it last time yesterday and measured the dowells to 7,96mm. They will not drop in, but a light tap with the hammer will drive them in and position them snugly. The hole is usually a bit larger than the nominal 7,9mm.
When getting the drill, shop for one that is precision grinded.
« Reply #4 on: May 16, 2011, 17:48:13 pm »
And keep the dowels in the freezer overnight. Makes life a bit easier. Wink
