October 14, 2026, 13:03:30 pm
| | |-+  Compu-Fire Ignition
Author Topic: Compu-Fire Ignition  (Read 3886 times)
Derjava66
« on: April 12, 2011, 06:58:50 am »
Does anyone out there know if the compufire points replacement unit will work with a 6 volt sytem? I have looked all over the place and they dont advertise the operating voltage. The pertronix unit states that it works between 8-14 volts is the compufire the same? Huh
RichardinNZ
« Reply #1 on: April 12, 2011, 10:12:17 am »
Sorry, I'm not sure about the Compu-Fire ignition.  But there is a version of the Crane Fireball that works OK on 6volts. I ran it for about 7 years on my Notchback with no problems, until I was moving from England to New Zealand and needed to sell the Notch. It broke down on the Test Drive; fortunatley the person still bought the car.
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
johnl
« Reply #2 on: April 12, 2011, 15:23:39 pm »
Does anyone out there know if the compufire points replacement unit will work with a 6 volt system? I have looked all over the place and they don't advertise the operating voltage. The pertronix unit states that it works between 8-14 volts is the compufire the same? Huh
Pertronix does offer a 6 volt negative ground unit for the Bosch 009 Distributor.  I can supply this unit, but don't stock it as the sales just aren't there.  Should you need further info please send me a private e-mail.  john@royze.com
glenn
« Reply #3 on: April 12, 2011, 15:35:56 pm »
The Pertronix 1844N6 works in the 019 and 010.
Glenn
www.DasVolks.com
Long Island's Aircooled Club
