June 10, 2026, 05:48:21 am
mvptkfjb
Berg 4 quart studs.
Topic: Berg 4 quart studs. (Read 5487 times)
Taylor
Berg 4 quart studs.
April 22, 2011, 08:14:30 am »
So I have an old Berg 4 and can't find studs for it. Aside from the cheesy factor and the fact that the material is usually softer, are there any other downfalls to using all thread? Taylor
Jason Foster
7.69 87mph 12.35 106 mph
Re: Berg 4 quart studs.
April 22, 2011, 13:35:57 pm »
Have you called Berg?
Frenchy Dehoux
April 22, 2011, 16:48:30 pm »
Taylor let me know if you can not locate them how many do you need. Do you need the sleeves for them.
Frenchy
Doctor Detail ( Retired )
deano
April 22, 2011, 22:07:46 pm »
Try using bolts instead of studs. Thread them from the case, down, and from inside the sump, down. A little tricky tightening them from inside, but I feel it is a much stronger setup than 6mm studs.
Anglia Obsolete Guru
'67 Heaven
April 22, 2011, 22:34:17 pm »
Quote from: deano on April 22, 2011, 22:07:46 pm
As above
Taylor
April 22, 2011, 22:54:45 pm »
I would do that as it would make taking the sump plate easier but the sleeves are lodged in there pretty good. I would like to find some studs but I'm not against all thread as the torque is only like 10 lbs.
April 23, 2011, 02:09:13 am »
Taylor, call Berg, they have the older hardware. If you want to stay original. Talk to Mark V.
Ted
Taylor
April 23, 2011, 03:07:09 am »
Thanks guys ill try Berg Monday. I was told when I ordered a pick up tube that they didn't think they still had them.
April 23, 2011, 03:15:40 am »
The last time I talked to Mark they had'em. I needed a set for somebody but they changed there mind.
Ted
April 23, 2011, 05:29:04 am »
I talked to Tim about a year ago and he told me they had none and they would not be making any.
