September 25, 2026, 04:17:56 am
| |-+  For sale!
| | |-+  AJ Sims turbo prepped heads
Author Topic: AJ Sims turbo prepped heads  (Read 4120 times)
flatfire
« on: April 27, 2011, 10:10:55 am »
For sale a pair of AJ Sims prepped heads. These are brand new just arrived. I have taken advice on these beasts and maybe my bug and its driver are not up to the task of making the most of these amazing heads. The turn around at the moment on AJs heads is long due to his success with the Red Baron. The price is £2300 firm.
My contact details 07923 365 567 (UK) email peter@caledonian-ecoplumb.com
Super flow Pro Heads
Berg thick 48mm intake seats with 40mm exhaust seats, Chamber volume 69.8cc, Titanium Inlet valve (48mm) stainless 40mm
Ti Manley retainers, Manley .05"drop keepers,
re-cut pushrod tube surface angle to seal, Cut and set up for K800 springs, Bore 94mm ,Turbo use for over 700hp. Can run up to .720" lift at the valve. All Work and Hand Porting is by A.J.Sims.
I also have a LBC5.0ProOnly cam to go with the heads including AJs lifters £180
The winners choice when it comes to real HP numbers. Main RPM power range 4,000 to 8,000. Over .580" lift with 1.5.
One more item I have set of alumium manifolds that are being currently built. £200
[imghttp://im1.shutterfly.com/media/47a1da06b3127ccefca2f974635e00000030O08AcsWLJw0ZtQe3nwY/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/]http://[/img]
flatfire
« Reply #1 on: April 29, 2011, 08:56:30 am »
I have ordered a 64 ounce steak. I'm going to eat it.  Smiley
Heads no longer for sale I'm going to build the engine.
« Reply #2 on: April 29, 2011, 11:05:20 am »
Good choice,
Best of luck with the build. Should be a monster
Lee
flatfire
« Reply #3 on: April 29, 2011, 15:41:21 pm »
Thanks Lee.  Smiley
