September 25, 2026, 04:18:09 am
| |-+  For sale!
| | |-+  K- Motion valve springs
Author Topic: K- Motion valve springs  (Read 2681 times)
Tomi
« on: April 27, 2011, 15:39:00 pm »
Shawn Geers valve springs for roller cam. 1.45" od. New. Sold.
Advertized pressures
240lbs @ 2.0"
560lbs @ full lift
coil bind 1.15"
K- Motion K800 valve springs, new. 60 eur.
JayCee 190 000psi push rods, new. Sold
Offers welcome. ts(a)welho.com or pm
« Last Edit: May 10, 2011, 09:33:30 am by Tomi » Logged
Tomi
« Reply #1 on: May 07, 2011, 13:27:08 pm »
Cam is sold, others still available. Measured the actual spring pressures and they're as follows.
Shawn Geers:
Coil bind 28.5mm
500lbs @ 2.0mm from coil bind
240lbs @ 18.5mm from coil bind
K800:
Coil bind 26.5mm
490lbs @ 2.0mm from coil bind
200lbs @ 18.5mm from coil bind
« Last Edit: May 07, 2011, 18:03:18 pm by Tomi » Logged
