September 22, 2026, 09:51:44 am
What 14" tire to use.....
Topic: What 14" tire to use..... (Read 9705 times)
May 13, 2011, 07:25:06 am »
What 14" tire to use on 14" Alloys up front that would be considered
Cal-Look
Ted
Re: What 14" tire to use.....
May 13, 2011, 09:56:22 am »
michelin 145 MX i've those on my 14" empi 8
will take a picture ted
Last Edit: May 13, 2011, 12:59:38 pm by speedwell
May 13, 2011, 13:04:46 pm »
similar to an michelin XZX
May 13, 2011, 13:06:05 pm »
A 145/14 is gonna be a little short, IMO. I'd go to a 155 if it's available.
Dave Rosique
nobodyouno
May 13, 2011, 19:33:03 pm »
Hi Ted,
I just went through this a few months ago for my Oval, not much out there in a 14"
I ended up with a Firestone F-560 155-14
The tire is about the height of a 135, width is similar to a 145
I'll try to post some photos / measurements tonight.
May 13, 2011, 20:15:50 pm »
Thanks Dave. Have a set of 14's with tires. Forget the size at the moment, but they are a wider tire, not to Cal-Lookish. They low like a 145- 14 would be. Ran them on my beater 69' when I worked at Bergs. Don't look bad, just a little wide. When I get home from work, I'll check the size and post. See if I can get a pic also. Ted
Dave Rosique
nobodyouno
May 14, 2011, 01:54:16 am »
Here you go Ted,
The tire and wheel combo I have for my Oval:
New Firestone F-560, 155R14, mounted on 14X5.5= 23 3/4" tall, 4.5" tread width.
Just for kicks, my M&H specs: 215/65-15 mounted on late 15X6.0= 26 3/4 tall, 6.0 tread width.
Personally, I think the size, looks & profile of these tires are Cal-Look.
Cheers,
Dave
Dave Rosique
nobodyouno
May 14, 2011, 01:56:30 am »
More..
Dan Mazur
May 14, 2011, 02:01:14 am »
I want some rotors like yours, Dave!
Don't worry. It's mutual.
May 14, 2011, 02:15:01 am »
Quote from: Dave Rosique on May 14, 2011, 01:56:30 am
More..
Nice tire combo dave.
May 14, 2011, 02:42:14 am »
More..
Dave,
Let's see them on the CAR!
Lookin' good but I need perspective ...
Thanks,
TxT
May 15, 2011, 08:34:22 am »
Ok, here is a pic of my 69' beater with 15X6 Late's out back and 14X5.5 on front. And I still have the car.
Please don't laugh to hard.
Ted
May 15, 2011, 09:37:21 am »
i've got 155/14 michelin mx.
DVK ~
May 15, 2011, 15:08:44 pm »
Last time I tried to find 145/14 michelins they were unavailable. And that was 26 years ago.
May 15, 2011, 15:46:01 pm »
I dig 14's on the front of a looker, but you can't run dropped spindles with them on a ball joint car :/
May 15, 2011, 17:08:18 pm »
Quote from: Zach Gomulka on May 15, 2011, 15:46:01 pm
That's the only thing, I'll have to pull my drop spindles off and put on the stock disk on. BUT, I do have the front end that is in that beater pictured above. Stock width, one piece beam with adjusters, fully rebuilt with stock disk's. That is the plan is to switch out beams. Then run the wheels. I'll loose the ride some, but not to bad. I remember that the ride was not to bad.
Ted
