August 13, 2026, 11:37:03 am
Lotus67
What size of and type of fuel line and pump works best with 2L plus IDA Motor
Topic: What size of and type of fuel line and pump works best with 2L plus IDA Motor (Read 8898 times)
Russell
April 28, 2007, 09:46:14 am »
What size of and type of fuel line (bore diameter) and pump works best with 2L plus IDA Motor
I was thinking about useing a Holly 97 PPH "RED" and some 7mm aeroquip hose and fittings but wasnt sure if this would provide enought fuel for 2332cc drag motor ?
Any suggestions appreaciated.
Russell
Last Edit: April 30, 2007, 07:28:52 am by Russell Ritchie
Best Regards
Russell
Re: What size of and type of fuel line and pump works best with 2L plus IDA Motor
April 28, 2007, 17:21:22 pm »
The Holley pump will support it! I would consider some larger line though.
Bill Schwimmer
April 30, 2007, 05:20:08 am »
Yes ,the Holley pump would be fine. How much power do you think it would make ? I too think that 7mm line is a bit small. If you are using steel braided line -8 to the regulator & - 6 to the carbs would work fine. If you plan on making more than about 230 or so hp you might take a look to see what others are running to support that power level. Have fun Bill
" don't buy upgrades ride up grades"
Eddy Merckx
Russell
April 30, 2007, 07:28:09 am »
Bill Thanks
Yes Im planning to use -8 for both the tank to centre chassis fuel line and -8 all the way to the carbs, It 2332cc with a 221.6BHP
see below.
Best Regards
Russell
