September 24, 2026, 14:25:08 pm
List what you feel is the best PRIMER to use for quality result
Topic: List what you feel is the best PRIMER to use for quality result (Read 5097 times)
rick m
May 30, 2011, 07:39:45 am »
What are your preferences and experience with primer surfacers, epoxy primers, etc. What do you recommend for the best results.
RM
Rick Mortensen
Driving Hot VWs since 1970
Re: List what you feel is the best PRIMER to use for quality result
May 30, 2011, 13:19:05 pm »
I highly recommend GLASURIT products !
Tony Wilkie
May 30, 2011, 19:13:57 pm »
Hi Rick,
I like slick sand. (used it for 5+ years) And it is what we used when I worked at a Phoenix hot rod shop (open check book cars).
Easy to work with and very high build.
tw
Operations Trask Manufacturing
Design, Prototype, & Dyno Tune Custom Motorcycle Exhaust
SCOTTP
May 30, 2011, 19:25:37 pm »
I use Sikkens colorbuild tintable primer
Der Kleiner Panzers III
'63 Ghia Coupe
140" 2332cc powered Frameworks Dragster
'63 Notchback in the works
Dick Mitchell
May 31, 2011, 07:40:30 am »
I've heard REALLY good things about PPG NCP280 Primer/surfacer. This is the primer I plan on using in a few weeks on my car.
rick m
May 31, 2011, 14:17:24 pm »
Tony,
Where did you buy the primer you are talking about in Phoenix?
Rick M
Rick Mortensen
Tony Wilkie
May 31, 2011, 18:46:12 pm »
Hi Rick,
Young Sales in phoenix was our paint supplier.
tw
rick m
June 01, 2011, 06:52:49 am »
Thanks Tony. They are the same shop I go to. I will check it out. That is the one on 19th ave right?
Rick M
Rick Mortensen
