September 22, 2026, 18:37:41 pm
| |-+  For sale!
| | |-+  Vw german Looker Street-Beetle
Author Topic: Vw german Looker Street-Beetle  (Read 5430 times)
Maroon Baboon
« on: May 30, 2011, 19:16:23 pm »
Vw typ1 1972
No engine
Price:3800 euro
http://boxerville.se/forum/viewtopic.php?id=2378
The car is sold without a motor.
Sitting a Porsche gearbox 901 which is modified to suit the type 1
Half the construction cost
Stopping a tuned engine and you have a really pungent car
070-6799950
The following have been rebuilt and modified
1st Replaced / Modified Components
All bushings Urethane
Link arms until VW 1303 -74
Mod. Spiders (see 3.1) VW 1303 -74
Wheel hubs front Eg. approaches like. Aluminum AA 7075-T6 Bultdeln. 108 / 5 M12
Stabilizers VW 1303 -74
Strut Sachs, matching Suzuki Swift
Springs incl. using spring Sellholm Tuning
Top Storage VW 1303 -74
Rear shock Cofap gas
Drop Stop back Nedfjädringsstopp
Wheel hubs rear Mod. Typ3
Wheels 100 + DTM 16 "Bultdeln / The offset, Volvo 850
Front tires 205/45-16 "
Tyre, rear 205/55-16 "
New position for växelförararm Mod. Chassis
Color code for paint Scania Chassis Grey (darker shade)
Brakes
2nd Description
Vented discs on all wheels with 1-piston sliding rear yoke which has integrated hand brake. Two-circuit braking system with front and rear circuit. Master cylinder from Volvo. Steel braided brake hoses all around. Welded to the spindle for the brake calipers.
3rd Replaced / Modified Components
Brake calipers up Volvo 850 Ate
Brake disc front Volvo 850 Ø280mm T = 26mm
Holder for front yoke milled steel plate welded to the spindle.
Brake calipers Rear Subaru Leone (front)
Brake disc rear Mod. Volvo 850 Ø280-275mm T = 26-21mm
Holder for rear yoke Aluminum 7075-T6 the brake attachment
Master cylinder Volvo 240 Ate (left comp Refers to 740 in regbevis)
Brake lamp switch M10x1
Drivetrain
4th Brief description
4vxl Porsche box provides the original drive shafts
5th Replaced / Modified Components of the Transmission
Transaxle Mod. 4vxl Porsche 901 (911 -68, mod comp Hub)
Mod. Exp. Hub Adapter for Original shaft / hub
Pressure plate Kennedy Stage II, 1200kg / 217 ft. Ib
Rear växellådsfäste Eg. approaches like. Alu-beam Hockey Puck bush
Front växellådsfäste Eg. approaches like. Beams. Motor mount / Urethane Puck
Ing. Reversible mechanism Eg. approaches like. Alu
Derailleur lever set, awkward Volvo 850
Clutches
6th Description
Original tank with surge protection, self begets modified (divisible Cabinet) high pressure pump, fuel filter before and after high-pressure pump. Steel braided fuel line on the pressure side, returned to the tank filling. Solid fuel pressure regulator
7th Replaced Components
Fuel pump Bosch 0580254984 (12v 506289-13 cz)
Primary fuel filter?
Secondary Fuel Filter Volvo 740 (Biltema 52-0083)
Fuel pressure regulator volvo 740
Fuse box 2pc Universal, flat fuse
Headlights Golf type1
Flashers / lamp 5 / 21W (in bumpers, 5W not connected)
Starter Motor VW 1600TL automatic
8th Components live at the main power turned on
Brake Lamp
Dimmer switch
Horn
Radiator Fan Control to oil cooler
Starter feed
Ignition Switch
Start Button Dashboard
Start Button Engine Room
Kupe'fläktomkopplare Not diverted
9th Components live at the start position of ignition switch
Startmotorsolenoid
Bodywork
10th Description
Original Body, which shifted approximately 2.5 cm to the left of the rear mounts to get the wheel openings are symmetrical, and the anterior floor of the luggage is removed hijacked, rear part of the "floor" against the firewall is elevated approximately 20 cm, about 3.5-4cm expanded metal screens around, and removable "between the sheets" rear. Bumpers from VW in 1303 -75, after which lamps can be used for marker lights front and rear dimmljus when it sits dubbelpolslampor in brackets (5/21W). Running boards are moved 2.5 cm m.h.a. 25x25 tubes.
11th Replaced / Modified Components
Rear-view mirrors Mod. Micro car parts with the original attachment
Frontfenders Mod. VW 1303 -75 (broadened / hung 3.5 cm)
Rear wings Mod. VW 1302 (width approx: 4cm)
The front bumper incl. Mount VW 1303 -75
Rear bumper incl. Mount VW 1303 -75
The rear middle plate Mod. VW 1302
Color code for paint NCS.5502B Scania chassis (two comp truck paint)
Interior
12th Description
Fairly spartan interior with two race seats, cage, some carpet and a few instruments, recorded for a passenger.
13th Components
Fullbur missing a few tubes for racing regulations.
Chairs 2x Cobra Monaco, the adjustable frame
Oil pressure gauge Equs (electronic)
Fire Extinguisher 2kg
tonysandmark@yahoo.se
« Last Edit: June 05, 2011, 16:07:40 pm by Maroon Baboon » Logged
71CALRIPPER
« Reply #1 on: May 31, 2011, 07:28:44 am »
Now that I like Smiley
« Reply #2 on: May 31, 2011, 08:21:29 am »
That looks a steal at that price! Cool
Maroon Baboon
« Reply #3 on: May 31, 2011, 17:44:19 pm »
Give me a bid
Maroon Baboon
« Reply #4 on: June 01, 2011, 09:54:01 am »
Uppdate
Maroon Baboon
« Reply #5 on: June 05, 2011, 16:08:08 pm »
New price !!!!!
Maroon Baboon
« Reply #6 on: June 18, 2011, 17:16:05 pm »
Up  Undecided
