September 10, 2026, 12:19:12 pm
352302 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  Street and strip shocks
Author Topic: Street and strip shocks  (Read 15807 times)
69Stu
« on: May 02, 2007, 21:31:20 pm »
I am looking to change the shocks on my bug to something adjustable so that I can shange the settings between street and strip use, and hopfully improve the launch on the strip.
Does anybody have any suggestions?
I have been looking at the Avo double adjustable shocks, does anybody have any experience with using these on the street? and can they be set soft enough for a smooth ride on the front of a ball joint bug?
Cheers.
Stuart
Roman
« Reply #1 on: May 02, 2007, 22:10:56 pm »
I havent tested the AVO double adjustable, but I have tested the single adjustables. They are a bit to hard for my taste to use on the front on a bug aven on the softest setting. The on the rear in anoother anomal, they work great there.
Use stock shocks they do the work, old worn ones for the strip and new ones for the street.
« Reply #2 on: May 03, 2007, 07:16:41 am »
Koni?
69Stu
« Reply #3 on: May 03, 2007, 12:44:25 pm »
Thanks for the replies.
Roman
As i am not producing that much power, at the moment  Wink, I am looking for something that can be adjusted to act like a 90/10 shock on the strip, to get the weight transfered onto the rear tyres and keep it there, I am not sure that stock shocks will do this, and then be able to adjust them for a smooth ride home.
Zach
Have you used koni shocks?
« Reply #4 on: May 03, 2007, 16:02:22 pm »
Zach
Not yet- Ive got a set coming for my GTV bug although it will be daily driver use, hardly any dragstrip. I suppose if you set them up soft in the front and firm in the rear they would work great for weight transfer. Probably work well on the street in that configuration as well. I know there are a few fast street cars in the US that use them.
larry mck
« Reply #5 on: May 04, 2007, 01:19:32 am »
Do what I do, have two sets, stock for every day then change to the 90/10 for racing. It only takes a few minutes to change them. You will enjoy the nice soft ride of the stock shocks for every day. This is for the front. I use Konis on the rear.
Jordy/DVK
« Reply #6 on: May 04, 2007, 11:09:26 am »
 I have just recently fitted a pair of shorter Koni's (#80-1580) and they are great for everyday use...
 I have never used them on the strip though..
  "The Full-Throttle Cruisers"
oldbug
« Reply #7 on: May 08, 2007, 19:50:07 pm »
hi guys,
any references of all this shocks and where to find them ?
what will be the best combination for a strip bug (a little street) front and rear ?
thanks to all.
Laurent
