October 13, 2026, 00:15:31 am
What manifold for a Holley Bugspray?
Topic: What manifold for a Holley Bugspray? (Read 5378 times)
xavier
May 31, 2011, 22:49:51 pm »
Guys,
plenum or isolated runner type? What is best with a Holley Bugspray?
Thank you.
Xavier
Re: What manifold for a Holley Bugspray?
May 31, 2011, 22:54:29 pm »
If the carb has balance port between the barrels use an isolated runner.
rick m
June 01, 2011, 06:50:08 am »
I ran a plenum style on the first one I had in 1970/71. It worked well but then again it was on a big motor (92x72) with Norris cam. Later switched to duals.
RM
Rick Mortensen
Driving Hot VWs since 1970
Dave Rosique
nobodyouno
June 01, 2011, 18:43:23 pm »
^^^Yep^^^
Way back when I was a wee lad, the rule was "plenum with a Holley, isolated tube with a Zenith"
Around '75 or so, I ran a Holley Bugspray on a high compression 1835 that did pretty good (for a Holley
xavier
June 02, 2011, 09:06:08 am »
OK. For what I have seen and read both style were used(more of the isolated type).
What would trigger the decision? CC, cam, heads(single/dual),...
Thank you
Xavier
June 02, 2011, 13:29:51 pm »
The way I remember it was Holley on isolated manifold. Zeniths were a little different... you could buy a new carb from say Auto Haus that was "set up" to be used as a single. These worked best on a plenum style manifold. There were plenty of Porsche Zeniths around, too but these came with different emulsion tubes and seemed to do better on an isolated style manifold. The Porsche style emulsion tubes are marked S1... the others were marked K4.
