October 15, 2026, 01:45:52 am
| | |-+  Bosch coil issues? Grrrrrrrrrrrrrrr
Author Topic: Bosch coil issues? Grrrrrrrrrrrrrrr  (Read 4638 times)
65bug
« on: June 06, 2011, 02:29:11 am »
Hey guys,
    Alright. All systems go on the motor! Been trying to start, but no juice to the motor! No spark at all. I am running a Bosch 009 coil and a Mallory Unilite Distributor. When I was hit from behind in the accident, the cb hex bar was sitting on top of the alternator. Arching away, it finally developed into a little fire. Once I got the linkage off the alternator, it stopped it.
    It fried the alternator wire going to the starter. Melted the insulation about 12 inches back. Fixed that.
    Big question is: could this have fried my coil?Huh I used a multimeter to check the coil and got no voltage with key on. I know the Mallory unilite distributor hates any type of voltage spike, but the control module does not smell burnt at all.
    Oh, I should have one black wire coming out of the harness on the left that goes to the coil. Correct? And anyone know of another way to test my coil??
Thanks!           PS Scratching my head here! But getting over a cold, so I could be screwed up! Cheesy
fredy66
« Reply #1 on: June 06, 2011, 04:14:59 am »
have you looked at the fuses? test a nother coil
arabia slugs
65bug
« Reply #2 on: June 06, 2011, 04:21:58 am »
Thanks fredy66! Yes, fuses looked good from what I could tell. Seems everything is good. I will check coil again tomorrow, then go buy a new one if need be. I am going to call MAllory and speak to a tech guy about the resistor they recommend! It worked fine before the accident.
Thanks!
fredy66
« Reply #3 on: June 06, 2011, 05:00:56 am »
Hey guys,
two  believe one to the oil and one to the coil
arabia slugs
