April 11, 2026, 05:09:10 am
352104 Posts in 28882 Topics by 6917 Members
Latest Member: joni75
| | |-+  F"ck...might have taken it too far
Author Topic: F"ck...might have taken it too far  (Read 5510 times)
« on: June 08, 2011, 07:10:00 am »
Hey Guys,
while torquing up the scat gland nut, i heard some "crack" at the end...
i hope it was the wrench.... Is it possible to break these gland nuts or crank?
I used a 1 m torquewrench and put all my weight (80kg) and some more on it
Please tell me i dont have to tear it apart again  Cry
« Reply #1 on: June 08, 2011, 07:17:46 am »
Try taking it off, got nothing to lose. Check the gland nut. I use Berg gland nuts w/o no problems.
« Reply #2 on: June 08, 2011, 07:22:57 am »
I will be suprised if you have managed to break the Scat gland nut. Beside, it would be loose if it broke because it will immediately loose its torque. I have, in order to get my wedgemate to mate, used 2000nm on a Scat nut once without any issues at all and the same crank is in my engine today. 650 - 900nm is quite common as far as I know.
I sincerely hope you did not hurt your crank.
BB
Hey Guys,
« Reply #3 on: June 08, 2011, 08:47:13 am »
thanks guys,
i checked if it had lost its torque, but the "head" was still tight...
the crank is a dpr, so good qualitiy....
i might be getting paranoid Smiley
i will get teh KEP off today and put my full weight on it again...
i guess it will be ok if the head doesnt fall off
« Reply #4 on: June 08, 2011, 08:58:39 am »
thanks guys,
Good. Usually with a press fit on you will get a "PING" - "CHING" or "BONK" sound  Smiley when flywheel is where it should be. To make the job easier you can take a hammer and knock on the 38mm pipe, then try the wrench, knock again, wrench.. you get my point.
« Last Edit: June 08, 2011, 09:01:01 am by BeetleBug » Logged
« Reply #5 on: June 08, 2011, 09:57:06 am »
Thanks Kalle,
you are putting my mind to rest Smiley
