September 24, 2026, 05:41:00 am
| | |-+  DRD H beam rods
Author Topic: DRD H beam rods  (Read 9338 times)
Rune
SCC Crew
Screwdrivers #7
« on: May 05, 2007, 18:55:16 pm »
Collecting parts for my new engine, and I don't really know what rods to go for. Anyone tried these?
http://www.thesamba.com/vw/classifieds/detail.php?id=363061
Jordy/DVK
« Reply #1 on: May 05, 2007, 19:38:13 pm »
 No... but if I were you I would refer to this ad (read the text)... http://www.thesamba.com/vw/classifieds/detail.php?id=315415
 Also DRD and also Darren Gurrola but $10,- cheaper... Grin Wink
 I am also curious about these...
« Last Edit: May 05, 2007, 19:39:50 pm by Jordy/DVK » Logged
  "The Full-Throttle Cruisers"
besserwisser
« Reply #2 on: May 05, 2007, 19:50:46 pm »
Same old stuff in a brand new bottle. All H-beams and I-beams are made in China. The only difference is the quality of the rodbolts and how accurate they are machined.Spend the money on the rods because a failure ther is very bad for youre wallet. Cb sells them so does Scat, Empi has them and several fly by night companies sell them for less but with weaker bolts and some even sell rejects. Itīs a jungle out there.
Rune
SCC Crew
Screwdrivers #7
« Reply #3 on: May 05, 2007, 20:03:46 pm »
That's what I thought. The add states ARP 5/16 or 3/8 rod bolts, but I read something on the other cal-look forum about some rods on the market having "fake" ARP bolts. Not sure on what to belive...
He allso states that the rods are checked over and balanced in house..
My budget won't allow fine rods like carillos, what rods should I go for.
« Last Edit: May 05, 2007, 20:05:54 pm by Rune » Logged
« Reply #4 on: May 05, 2007, 23:34:43 pm »
I bought cb ones that come with arp 2000's,
i think these are good rods..
some extra insurance maybe..
Alan Uyeno
« Reply #5 on: May 06, 2007, 05:12:42 am »
Scat 3/8 rod bolt Hbeams puts a little more confidence in a rod. However the old school Hbeam Eagles have worked extremely well with the 5/16 rod bolts.
I'm using 5.5 CB Hbeams with ARP bolts for my 2nd 2332 engine. That engine was a breeze in terms of clearance.  CB Hbeams seems to have a good .018+ side clearance on many conrod journals regardless of crank brand. I guess its good for flow but an oil pump better provide the flow to keep up. It should be fine though. Scats seems to be on the tight side for sideclearance and getting them machined/skimmed for more sideclearance is a good idea for high revvers.
SteveW
« Reply #6 on: May 08, 2007, 09:11:54 am »
I'm starting to plan my new engine for the '59 and I've been doing alot of reading and it seems Carrillo rods, while expensive, are very good. My budget will allow for Carrillo's so what do you guys think, are they worth it? My application will be a 2332/2387, high compression (we want to run 11's NA)
Steve
Steve
1961 Oldspeed Beetle
1970 Stock Beetle.
« Reply #7 on: May 08, 2007, 11:48:25 am »
carillo is one of the best rods so no problem there.
Alan Uyeno
« Reply #8 on: May 09, 2007, 04:43:01 am »
Steve
It'll be easy get into the 11's running a high compression engine.  You should consider scat Hbeams with scat ARP 3/8 rod bolts. The rod bolts is the weak link. There are many hardcore guys at the track  beating on Scat H beams for years with little issues.
