September 21, 2026, 19:50:01 pm
| | |-+  turbo cams
Author Topic: turbo cams  (Read 15859 times)
Andy Sykes
« on: June 11, 2011, 19:48:40 pm »
hi first of all this may have been done to death but i couldnt find much using the search,
currently my longblock was set up for N/A at 9.5:1 i have decreased this to 8:1 when i fitted the T04B but since im going bigger and putting a lot of time into the car im going to split the case and change the cam
basic spec is
2332cc
denham heads (og castings) welded and ported
cb case
DTA EFI
NOS
intercooled
water injection
turbo spec as follows
Compressor Wheel Inducer - 65.0mm
Compressor Wheel Exducer - 92.0mm
Turbine Wheel - 83mm
T4 Twin Scroll  .90ar
what cam would you guys go for and is it worth going to roller cam?
cheers andy
volkskris
« Reply #1 on: June 11, 2011, 21:00:27 pm »
JPM. the best out there. Wink
Andy Sykes
« Reply #2 on: June 11, 2011, 21:30:24 pm »
this guy?
www.jpmotorsport.se
cheers andy
« Reply #3 on: June 13, 2011, 02:57:08 am »
Yes ... Johannes Personns (the JP of JPM)
He's the Man.
Ragtop
8.93 at SCC 2012
« Reply #4 on: June 13, 2011, 11:14:22 am »
I use his cam in my engine. Very nice!
« Reply #5 on: June 13, 2011, 14:37:04 pm »
I know Matt Keene (All Torque on here) uses a JPM cam in his wasserboxer, and picked up a load of horsepower. He'll probably chime in with what exactly he did, but if I'd got a motor of your spec, I'd certainly be looking at JPM. Not cheap though...
StrokerMcDell
« Reply #6 on: June 13, 2011, 18:40:37 pm »
Copy of email from Johannes when I enquired about price.
Ive decided not to go to all the extra expense and just get a WebCam 86B on 112 lc
I think i read somewhere that Matt originally ran a WebCam custom 86B/86C which was replaced by the Raptor.
Hello,
JPM01012T
 Matched lifters, brake in oil and paste are included in the kit.
Raptor cam kit is 4995sek or aprox £454pound, custom is £635pound.
Shipping to UK aprox 33pound.
Johannes
ACE 116
10.67 @ 123mph York 2010
10.89 @ 125mph York 2009
Momentum 99octane pump gas
« Reply #7 on: June 13, 2011, 19:50:37 pm »
Did you decide not to buy a Raptor even though you have read about Matt and his experience? Did you miss the fact that without changing anything but the cam he dyno`d a lot more HP?
Andy Sykes
« Reply #8 on: June 13, 2011, 20:19:19 pm »
thanks guys ive been in contact with johannes today hes has my info so we will see tmw but looks like this is the way forward
cheers andy
StrokerMcDell
« Reply #9 on: June 14, 2011, 13:24:26 pm »
Nope, I didnt miss any of that.
Without doubt Johannes' cams are extremely good ,
I just dont need (or for that matter can I afford) a cam that will make 450hp when all I NEED is 400hp.
I think there are too many guys out there who feel the need to go balls out on everything !
If it was a custom grind WebCam 86b / 86c ( and i'm not sure if it was ) then I'm not surprised he got a better result with a different cam !!
regds
ACE 116
Andy Sykes
« Reply #10 on: June 19, 2011, 16:57:16 pm »
Johannes has got back to me today with his recomendation
"JPM01712T should be very suitable for your combo.
It has 258deg at 0.05", 9.57mm cam lift and 113deg LC"
so its on its way soon
cheers andy
mrmut
« Reply #11 on: June 30, 2011, 17:43:17 pm »
basic spec is
2332cc
cb case
DTA EFI
NOS
intercooled
water injection
in - FK8\ ex - FK7   for street race , hot street race in - VZ30\ ex - VZ25
in - FK89\ ex - FK87 for Drag , for Drag Racing in - VZ35\ ex - VZ25
any of these cam. Lobe Centar 112deg or 114deg
« Last Edit: June 30, 2011, 19:47:44 pm by mrmut » Logged
markvo
« Reply #12 on: July 03, 2011, 11:14:24 am »
What does the car weigh with you in it, gears, rpm range wanted? race car or........
mrmut
« Reply #13 on: July 03, 2011, 20:12:02 pm »
In my opinion the more rpm the more horsepower.
I would go like this.....
Beginning of 2500 maybe 3000 rpm to 6500 rpm Street Racing Car....
From 3000-3500 to 7500 - 8000 Drag Race Car........
How would you bullets.
(1,600cc x 5500rpm x10,5CR)\910=101.5HP
(1,600cc x 6500rpm x10,5CR)\910=119.9HP
(1,600cc x 7500rpm x10,5CR)\910=138.4HP
(1,600cc x 8500rpm x10,5CR)\910=156.9HP This looks at Honda VTEC VTI  Wink
--- Always leave more horsepower
In my opinion here would look like this
1Bar - boost
8:1 CR
8x(1+1)=16 Real compression  (16:1)CR
(2.332x6500x16)/910=266HP  According to experience  310HP
(2.332x7500x16)/910=307HP  According to experience  358HP
(2.332x8000x16)/910=328HP  According to experience  382HP
Whenever possible horsepower
« Last Edit: July 03, 2011, 20:25:14 pm by mrmut » Logged
markvo
« Reply #14 on: August 01, 2011, 20:30:54 pm »
So very wrong mrmut
I doubt you tripled your horsepower with 1 bar of boost, at best double
If you double the compression from 8 to 16 to 1 you would only gain about 25.4% gain in power NOT the same as boost either!
mrmut
« Reply #15 on: August 01, 2011, 20:52:10 pm »
So very wrong mrmut
1Bar - boost
8:1 CR
I think with T4
We will achieve these results
You would grsham.
Prove to me your claim of 25.4%
Andy Sykes
« Reply #16 on: August 10, 2011, 21:46:42 pm »
well we will soon find out cam is here  Cool
cheers andy
Airspeed
« Reply #17 on: August 12, 2011, 22:00:22 pm »
Andy,
Please sell 1 lifter and get a normal camera. Your phone is meant to just call, obviously not making pictures  Wink
Andy Sykes
« Reply #18 on: August 12, 2011, 22:09:45 pm »
Andy,
my poor iiphone has had a hard life if i didnt keep spending money cars i would buy a new one lol
« Reply #19 on: August 12, 2011, 22:20:10 pm »
Andy and Walter, will I have the pleasure meeting you both in a week at SCC? You should come to get some turbo inspiration  Smiley
Andy Sykes
« Reply #20 on: August 13, 2011, 20:22:05 pm »
next year i wil be there when my cars finished  Grin
cheers andy
dannyboy
« Reply #21 on: August 13, 2011, 21:56:47 pm »
hahahahahahahaha this timenext year it will be in bits having improvements done as you will have a load more ideas to do Grin Roll Eyes Wink
8.77@156.8mph
O/FF 60
Andy Sykes
« Reply #22 on: August 13, 2011, 22:08:33 pm »
i cant afford to start messing about again unless i bolw it up   Roll Eyes the beach buggy is next on the list see if we can get that to run 10s lol
markvo
« Reply #23 on: October 02, 2011, 22:30:39 pm »
Do some calculating on here! www.wallaceracing.com/Calculators.htm
