September 25, 2026, 06:56:51 am
| |-+  For sale!
| | |-+  1" narrowed IRS a-arms
Author Topic: 1" narrowed IRS a-arms  (Read 5125 times)
beckr4
« on: June 13, 2011, 13:19:32 pm »
I have, tentatively, for sale a pair of 1" narrowed A-arms to suit a lowered IRS beetle.
I say lowered as they have been modified to reduce the camber experience with lowered IRS cars. They were fitted to Steve and Adele Woodbridge's Race car, quite a low rear end.
When fitted to the car they we also flipped left to right but that appeared not to be enough so the bend next to the pivot point has been adjusted (cut and welded).
All modification were performed by Wayne Allman (Intergalactic Custom Shop)
I have cut the shock towers off since I was planning on fitting these to a stock height rear end (cal-looker) the correct way up, but as they have been modified further than the narrowing they do not sit as if stock arms would.
I can supply the shock towers which came off
So these would suit quite a low car as they compensate well for the negative camber.
I can't supply any exact angle changes/modifications compared to stock, But Wayne Allman may be able to help if he can remember.
£200 or a reasonable offer
I got them for £250ish but were described as narrowed and flipped, and when I discovered they where also modified from stock elsewhere my happiness took a turn for the worse.
I am trying to be as open and honest as I can be, but I definitely don't know exactly what has been done since the previous owner also does not.
But these could save you a lot of work if they are right for you
I'll try and get some photos up ASAP
Here is the link to the original Advert
http://cal-look.no/lounge/index.php?...&topic=13491.0
JG54 Greenhearts
beckr4
« Reply #1 on: June 13, 2011, 13:52:22 pm »
Very good narrowing job
Some pictures of the modified pivot point. And some of a stock arm to try and show the difference.
Not easy though in pictures, but it's quite obvious.
« Last Edit: June 14, 2011, 09:05:11 am by beckr4 » Logged
JG54 Greenhearts
beckr4
« Reply #2 on: June 14, 2011, 09:05:31 am »
Bump with more pictures
JG54 Greenhearts
beckr4
« Reply #3 on: June 15, 2011, 13:31:17 pm »
bump
JG54 Greenhearts
beckr4
« Reply #4 on: June 17, 2011, 11:46:52 am »
Bump
JG54 Greenhearts
