October 14, 2026, 01:05:56 am
Axle movement
Topic: Axle movement (Read 4422 times)
Lee
Axle movement
June 18, 2011, 14:17:53 pm »
Hi,
I've recently changed the gearbox in my Oval for a later one(from a '68) and have fitted the shorter axles from the original box to it. It is currently bolted onto the floorpan minus the wheels and backing plates etc.
My query is. Is it ok to be able to move the passenger axle in & out half an inch or so, or will this movement be taken out once it torqued up?
Lee
Garrick Clark
Re: Axle movement
June 19, 2011, 21:48:44 pm »
Hi there.
Yes when you refit your back plates,bearings and bearing cap,then torque the castle nut the play will be no more.
Last Edit: June 19, 2011, 21:50:35 pm by GARRICK.CLARK
Air cooled Engine builder
Dougy Dee
Re: Axle movement
June 20, 2011, 12:33:17 pm »
Be careful moving those axles as the fulcrum plates can drop behind the axle spades and block them. (They are a bugger to repair without removing the trans.)
Now I always install the backing plates, spacers, bearing and seal cover before flipping the trans and completing the other side.
