September 01, 2026, 22:53:44 pm
| | |-+  flanged cranks
Author Topic: flanged cranks  (Read 10618 times)
Andy Sykes
« on: June 19, 2011, 15:47:34 pm »
Hi guys,
my current engine has a 8 dowel crank but im planning to go to 500bhp with a new turbo new cam etc i was planning only going to 300 ish when i had a custom flywheel made so i can mate a T1 to a G50
im splitting the case to fit a JPM cam so im going to fit a flanged crank so i have a few questions if anybody can help
1 who makes good flanged cranks?
2 do you think i could get my custom flywheel machined so i can fit it to a flanged crank?
cheers andy
SuperBeetle73
« Reply #1 on: June 21, 2011, 06:27:41 am »
Bugpack make good flange cranks, probably the most popular...
Street Legal 1303S - 11.5 @ 115 on treads
SPRasmussen
ET 10,54 - 197,65 at SCC 2011
« Reply #2 on: June 21, 2011, 07:25:56 am »
i got one for sale?
http://cal-look.no/lounge/index.php/topic,15450.msg227058.html#msg227058
Søren Rasmussen
Owner of The Ultra Rat
www.TeamAngoraRacing.dk
StrokerMcDell
« Reply #3 on: June 22, 2011, 11:19:15 am »
Don't think it will be possible to modify your 8 dowel flywheel to fit flanged crank.
There are 2 types of bolt pattern to consider the older 6 bolt + dowel bug pack version and the 8 bolt + dowel SCAT although I think Bugpack are using the 8 bolt pattern now and most are all T4 bearing mains.
Below pics are of a floater clutch for a 6 dowel bug pack crank (t4 centre main only)
« Last Edit: July 02, 2011, 18:48:57 pm by StrokerMcDell » Logged
ACE 116
10.67 @ 123mph York 2010
10.89 @ 125mph York 2009
Momentum 99octane pump gas
Andy Sykes
« Reply #4 on: June 22, 2011, 19:21:15 pm »
thanks for the info  Smiley  i think it may be possible to machine but i think im going to wedgemate what ive got and see how it goes i will have clutch control so that may help
cheers andy
Rick Sadler
« Reply #5 on: June 22, 2011, 19:22:28 pm »
All of the BUGPACK Flanged Cranks are now all Type-IV Mains and all Flywheels still remain 6 bolts with 6 dowels.
StrokerMcDell
« Reply #6 on: June 22, 2011, 20:25:53 pm »
isnt this bugpack crank 8 bolt with single locating dowel ?
ACE 116
Dominick Luppino
« Reply #7 on: June 23, 2011, 03:47:50 am »
Read Rick's post above yours.
Griebel
« Reply #8 on: June 23, 2011, 06:48:20 am »
Any bearings for flanged/all type 4 mains cranks available yet ?
Cheers from Griebel
Instagram: c.griebel
       "BEYOND 4 INCHES"
          MIB,DENMARK
StrokerMcDell
« Reply #9 on: June 23, 2011, 12:12:10 pm »
Thanks for that Doninick
It's not that I'm Dyslexic you know, I just made a mistake in thinking that pic was of a Bugpack crank.
But thanks anyway Roll Eyes
Regds
ACE 116
Rick Sadler
« Reply #10 on: June 23, 2011, 19:34:33 pm »
The bearing kits we sell (#4000-70) is for the JayCee style center thrust set-up. Vee Dub Parts Unlimited has the Bearing Sets for the cases that have been bored for Type-IV OD.
Carsten
« Reply #11 on: June 30, 2011, 12:30:12 pm »
/cC/f%3D0/ps%3D50/r%3D0/rx%3D550/ry%3D400/[/img]
Which kind / manufacturer of clutch is that ? Maybe need one next year for the new engine.
Greets , Carsten
1969 IRS bug
Rick Sadler
« Reply #12 on: June 30, 2011, 15:11:28 pm »
Greets , Carsten
That is a J&G Model Clutch
StrokerMcDell
« Reply #13 on: July 01, 2011, 10:01:09 am »
Yes it's an early J&G floater clutch assembly.
I spoke to Roger Crawford about this one and apparently the only difference between this and a newer one is that the new ones have red anodised covers.
You can get two diaphragms to suit your style of driving - a heavy and a lighter and you can also adjust the pressure by adding/taking off washers from under the small black spacer tubes that you can see in the second pic
This one was a spare that came from a UK race car called Bugster .
I havnt used it yet so can't really say how good it may be.
Regds
« Last Edit: July 02, 2011, 18:46:51 pm by StrokerMcDell » Logged
ACE 116
