November 02, 2026, 20:31:53 pm
| | |-+  Oil Temp Question
Author Topic: Oil Temp Question  (Read 8737 times)
Kaferdog
« on: June 19, 2011, 20:10:46 pm »
I'm sure it's been asked before but where is the best location to mount a VDO sender to monitor oil temp....?
1. Oil relief valve
2. Remote Oil filter
3. Sump plate
fredy66
« Reply #1 on: June 19, 2011, 20:16:43 pm »
i.m planing to mount in the sump (cb performans)
arabia slugs
« Reply #2 on: June 19, 2011, 20:52:45 pm »
If you have a universal case then the type 3 take off plate
Jesse/DVK
'64 2176cc
« Reply #3 on: June 19, 2011, 21:31:41 pm »
Anyone have an idea how far the oil level is in the case when filled up to top mark of dipstick? I have my temp sensor in the type 3 take off plate as suggest above but will the oil reach the sender?
dave greiner
« Reply #4 on: June 19, 2011, 21:33:04 pm »
The sump location will read 50 -80 degrees cold. The filter adapter would be the most accurate, but the pressure relief location is pretty close
and is easier to do. It takes a VDO 323064  18mm sender.
Cheesepanzer
« Reply #5 on: June 19, 2011, 22:02:09 pm »
Why not off a "t" in the stock sender location?
63 Type 2 Single Cab
Cornpanzers
« Reply #6 on: June 19, 2011, 22:04:56 pm »
Quote
probably not enough flow in that area...
« Reply #7 on: June 19, 2011, 22:26:46 pm »
Drill and tap the oil filter housing?
Brother Lovedub
« Reply #8 on: June 19, 2011, 22:36:16 pm »
Type 3 dipstick hole on a universal case
Kaferdog
« Reply #9 on: June 19, 2011, 23:03:34 pm »
Yeah thats what I did .....I was givin the wrong sender I wanted to install it on the sump plate ,but I think it worked out better for me ....! ...Also I was going to tap into it at the filter but thought this might be a better way ! as I don't have a universal case ...later I plan to maybe install a external fan as I will tap into there !.....I'm running about 190-195 nothing over 200 yet !...and that was coming back from "The Classic" ! which 100 miles or so...Now I just have to figure out a good way to run the wire neatly over the tranny..! ...."Anyone have any neat tricks"...?
fredy66
« Reply #10 on: June 19, 2011, 23:46:35 pm »
oil hoseis 8 m ok
arabia slugs
« Reply #11 on: June 20, 2011, 07:50:01 am »
One thing for sure, your motor is still clean, no leaks, at least what I can see Randy.  Grin Never used the pressure relief sender before, but was thinking, is there enough oil going under the piston to read right? I do like the idea of the Type III dip stick plate for the sender. It is in the oil at that location, just make sure your oil level is at full. Also, putting a sender in the sump plate especially a deep sump might not be a good idea, it's lower to the ground. May hit something. On the side of the sump is fine.
The oil temps your getting now seem good, need to run it on longer to get it to max temp. An external cooler is a good idea anyway, safer for a hot day.
Ted
glenn
« Reply #12 on: June 20, 2011, 11:49:24 am »
Mine's in the oil filter.
where ever you put it you have to confirm that it is accurate. Mine reads 40* hotter than it actually is. I confirmed this with a Pyrex calibrated Deep Fry thermometer down the dipstick and with a Raytek infrared thermometer.
Then you look for variations from "normal" more than actual temps.I just returned from a 300 mile trip to the Litchfield show where I was pulling long hills up to 9% grades and temps never exceeded 205F.
Glenn
www.DasVolks.com
Long Island's Aircooled Club
Kaferdog
« Reply #13 on: June 20, 2011, 18:44:36 pm »
Well ...for now at least I can see more or less what the temp is until I find a solution to mount on the filter this will work for now !
