October 14, 2026, 19:29:28 pm
Rear wheel bearing puller
Topic: Rear wheel bearing puller (Read 9808 times)
June 20, 2011, 19:27:20 pm »
Has anybody got any idea what type of puller I can use to remove the rear wheel bearings.
don't give me another handy tips like hitting the axle until you can get behind the bearing.
I would like a puller that fits in between the bearing.
Re: Rear wheel bearing puller
June 20, 2011, 23:17:51 pm »
What I have done with swingaxle is to use a gear puller (I only have a 3 finger style) and pull the axle housing behind the bearing until I have enough room to behind the bearing. You will need to undo the axle house in order to do that, but it worked for me. It really is the best way. The VW puller pulls the internal race off the axle. I don't have that tool so I improvised...
peach_
June 20, 2011, 23:24:50 pm »
Quote from: Lids on June 20, 2011, 19:27:20 pm
Got to Machine Mart adn you can get a cheap set (different sizes) for around £15-£20 the others will come in useful somewhere else
SAS RENN-WAGENS
and proud
#CALLOOKDRAGS
June 21, 2011, 06:07:45 am »
Peach do you have a link?
June 21, 2011, 08:20:07 am »
I bought a cheap one and weld it on the bearing...
June 21, 2011, 10:05:34 am »
I would like to reuse the bearing as it has never been turned!
No handy tips please, I would like to buy a bearing puller that works on the rear wheel bearing without damaging it.
I have a 3/4 arm puller but the problem is the bearing seats in the axle tube just enough so you can't get behind it. I have used the old trick of hitting the axle and forcing the bearing down, but would rather not do this.
Last Edit: June 21, 2011, 11:21:47 am by Lids
June 21, 2011, 13:08:23 pm »
There is a drawing in the VW idiot book how to make a rear wheel bearing puller. Basically a puller with threaded rods thats have been grind to slip between balls of the bearing. But I don't know if the bearing is damaged or not.
black_bullitt
June 21, 2011, 17:57:26 pm »
I've got one of these, works a treat.
http://www.machinemart.co.uk/shop/product/details/cht249-14-pce-bearing-separator-angle-ge
June 21, 2011, 18:35:10 pm »
Quote from: black_bullitt on June 21, 2011, 17:57:26 pm
thank you, how does it work? does it fit inside the bearing?
June 22, 2011, 00:18:24 am »
Here is a photo of my Factory VW German puller made for pulling that bearing.
June 22, 2011, 10:04:25 am »
factory tools, saweeet!
DVK ~
kingsburgphil
June 22, 2011, 22:32:30 pm »
Quote from: Richard Roth on June 22, 2011, 00:18:24 am
If my weak memory still serves me, the collet puller shown came in two variants. An eight and a nine ball puller,
depending on the bearing.
God, I hope it's not my CRS flaring up again
June 22, 2011, 23:01:37 pm »
I have four variants of the same puller !
