July 01, 2026, 12:13:33 pm
bigsiembowski
Rechargable impact gun
Topic: Rechargable impact gun (Read 14840 times)
65bug
June 21, 2011, 04:12:41 am »
Hey guys,
Anyone using one of those rechargeable impact guns to work on their car? My wife bought me one of those oscillating scraper/grinder/cutter thingies for fathers day.. I do not really think I would use it all that much. However, a cordless impact driver could really save me alot of time. I only have a small compressor. so I thought a cordless would work well.
Russell
Re: Rechargable impact gun
June 21, 2011, 07:54:03 am »
yes i have a couple they are from sealy (machine mart) and work really well better than noisy compressor
Best Regards
Russell
June 21, 2011, 09:12:01 am »
i've got airtools and a compressor with insufficient capacity.
never heard of rechargeable impact guns. how about a visual e.g.?
DVK ~
Kaferdog
June 21, 2011, 10:39:14 am »
Quote from: 67-indeed/DVK on June 21, 2011, 09:12:01 am
http://www.craftsman.com/shc/s/p_10155_12602_00917339000P?keyword=c3&prdNo=2&blockNo=2&blockType=L2
June 21, 2011, 10:53:54 am »
pretty nice, is it as strong as an air impact gun wrt undoing bolts?
how does it differ from a good cordless drill/screwdriver like DeWalt?
DVK ~
jaqo
Bugster Team
June 21, 2011, 11:20:00 am »
i use this one
It's veeeery powerfull, you can undo a flywheel gland nut in 2 sec without blocking a flywheel - only holding it by hand.
65bug
June 21, 2011, 14:47:52 pm »
Thanks! That Craftsman actually looks really nice. The price is right too. That Snap-On I am sure is better, and probably at least 3 times the price.
Martin
Cash Converter....
June 21, 2011, 15:22:01 pm »
Quote from: jaqo on June 21, 2011, 11:20:00 am
i use this one
Expensive, but the best. I use mine loads.
Martin
www.taylormachine.co.uk
OFF/500
Kaferdog
June 21, 2011, 18:12:44 pm »
I have been thinking about getting a Craftsman for a while now ...Price keeps gettin lower I have never used one ...? but use the other cordless tools they have that use the same battery and "loveThem"....! so I'm thinkin it will work well ..!
June 21, 2011, 18:32:41 pm »
I have a cheap one from Harbor Freight and it works pretty well. I'll probably replace it with a decent one when it fails
mg
June 21, 2011, 18:43:06 pm »
Quote from: DKK Rick on June 21, 2011, 18:32:41 pm
Same here, was like $30 10 years ago, when it fails I'll look at Makita.
The Snap on variable speed trigger is butter, mine is more an off on switch now.
They make bigger but 300 ft.lbs should be enuf,
http://www.makita.com/en-us/Modules/Tools/Default.aspx?CatID=5
fixed typo
Last Edit: June 22, 2011, 01:55:30 am by mg
June 21, 2011, 19:32:25 pm »
I've got one and an electric (110v) one -- never use it enough so when I do want to use it, the battery is dead lol So I haul out the extension cord and use the plug in one -- I really like it alot -- has a lot more baulz than the cordless
http://www.craftsman.com/shc/s/p_10155_12602_00927990000P?keyword=impact&prdNo=9&blockNo=9&blockType=L9
Last Edit: June 21, 2011, 19:37:29 pm by Fiatdude
http://selvedgeyard.com/
Speed-Randy
June 21, 2011, 23:22:25 pm »
Quote from: mg on June 21, 2011, 18:43:06 pm
They make bigger but 300 in.lbs should be enuf,
300 inch pounds is only 25 foot pounds.for axle nuts/ gland nuts, NOTHING beats a torque multipler tool, 300 foot lbs with a 3/8 ranchet all day long
www.vdubspeedshack.com
RhoadsVW
June 22, 2011, 00:04:51 am »
I had all the air tools but took most of them to Goodwill and have a couple battery tools. Use them all the time. No more dragging air hoses all over the place. Really convenient. Dave Rhoads
Der Renwagen Fuhrers
65bug
June 22, 2011, 00:32:49 am »
Dave,
I am wondering if the plug ins would be good enough for me here at the house? I know of a few of them that could really save me some serious time. The impact driver would be a nice place for me to start.
jaqo
Bugster Team
June 22, 2011, 00:53:03 am »
Quote from: Speed-Randy on June 21, 2011, 23:22:25 pm
Not true, i have a torque multiplier and it's very good for bolting things, but for unbolting them impact guns are better - don't have to hold or lock things like flywheel etc, and they are faster. Not to mention seized bolts i.e. suspension
Last Edit: June 22, 2011, 00:54:43 am by jaqo
Speed-Randy
June 22, 2011, 05:48:47 am »
Quote from: jaqo on June 22, 2011, 00:53:03 am
Your right, putting a bolt thru a flywheel locking tool is just SO time consuming. Not to mention how much fun extracting broken gland nuts from a crank shaft is. Trusting that a battery is at full charge to get to 300 foot lbs, are you sure? I have a tool drawer full of pneumatic tools that never get used. Mainly because I like FEEL the ratchet tightening the bolts so I KNOW that it wasn't cross-threaded and going to snap when it hits 30lbs.
June 22, 2011, 09:27:40 am »
firstly, i never knew these rechargeable impact guns existed, thought it was an air tool only. then idid a little searching on the web but found that the makita guns at least cost 300-400 euros!! wowzers, are there any cheaper, fair-enough items available on this side on the pond?
snap-on is prob. expensive and hard to come by here.
and craftsman is sold in U.S. only?
DVK ~
mg
June 22, 2011, 13:10:25 pm »
Cheaper version, rated 211ftlbs.
http://www.harborfreight.com/18-volt-12-cordless-impact-wrench-67845.html
I just use it to remove lug nuts.
qubek
June 22, 2011, 14:11:16 pm »
Quote from: Speed-Randy on June 22, 2011, 05:48:47 am
I'm not trying to convince you, as I guess you will stick to your opinion anyway, but I'll say that I use the snap on one only from time to time and still it has already saved me probably a few hours of work. In case of jaqo, whom I see with this tool all the time, you would most likely have to count the saved time in days.
We're not talking about tightening the gland nut with it. You need a torque wrench for that, so a torque multiplier is the right tool for the job.
But for unbolting - it's so much faster and easier (especially when you're working alone and there is no one around to give you a hand) and this should be obvious for everyone who had a chance to use both this tools for this particular task.
As for this specific snap-on tool, it proved to be surprisingly useful. The trigger works great. I'm not talking about obvious things like removing rusted nuts in seconds without damaging anything, drilling, repairing threads etc, or removing rear brake drums or flywheels. Even simple tasks, like bolting and unbolting wheels... sure, this things can be done easily in a normal way, but with this gun, it's faster, and if you have to do it a few times during a day. Or this
http://www.youtube.com/v/UG58c9NDewg
I know it's silly, but what I want to show is that it is far more useful than I originally thought.
I don't say that craftsman on is much worse (or at all). I have access to snap on, I never tried craftsman.
65bug
June 23, 2011, 05:06:04 am »
I just want a decent one to use in situations where I have alot of bolts to remove. You know, lug nuts VW fenders and so on. I think the Craftsman plug in model would be fine for me. I bet it has more oats too then the rechargeable units!
