October 14, 2026, 08:19:44 am
| | |-+  Sump Quiz....
Author Topic: Sump Quiz....  (Read 11292 times)
deano
« on: June 21, 2011, 05:07:01 am »
Found this interesting sump at Sacramento, well made, but it has no names anywhere on it. Looks kinda like a Lang... Any ideas?
Anglia Obsolete Guru
'67 Heaven
kingsburgphil
« Reply #1 on: June 21, 2011, 05:36:09 am »
Just a guess... S&S,  Saurer & Sohn?
dave greiner
« Reply #2 on: June 21, 2011, 06:02:53 am »
I still have one on my motor! I'm pretty sure that it is a Lang. We used to sell them at Auto Haus.
« Reply #3 on: June 21, 2011, 07:41:15 am »
I don't think it's a Lang.
A Lang sump has a few innovative features that aren't in that one.
bugnut68
« Reply #4 on: June 21, 2011, 16:41:39 pm »
Not related to the post, but I passed on a Berg 3.5 qt. sump (no hardware, sump only) at Sac... I didn't bother to ask what he wanted for it because he went off on an unwarranted yet brief rant about the difficulty in getting parts directly from Bergs... so I pretty well figured it wasn't likely to be a bargain.  lol.  Perhaps my loss.
« Reply #5 on: June 21, 2011, 17:35:00 pm »
Empihaft? Treuhaus? Bergpack?
Frenchy Dehoux
« Reply #6 on: June 21, 2011, 22:05:50 pm »
  Looks like a version of Race Trim from Auto Haus.
   Frenchy
Doctor Detail ( Retired )
Gary Justus
« Reply #7 on: June 21, 2011, 22:43:33 pm »
Lang.
2manytoys
« Reply #8 on: June 22, 2011, 05:50:45 am »
Deano,...how much did you spend?
http://www.thesamba.com/vw/classifieds/detail.php?id=1155295
P-
Patrick Friel -..2manytoys, not enough time or money
deano
« Reply #9 on: June 22, 2011, 06:15:53 am »
About the cost of a sixer of Coronas....
But it is exactly like that one on thesamba... small world.
'67 Heaven
edcraig
« Reply #10 on: June 22, 2011, 06:37:00 am »
I agree...Lang.
« Reply #11 on: June 22, 2011, 10:03:58 am »
What kind of innovate features did you mean Bruce?
It definitely looks like a Lang, and nothing else IMHO, perhaps an early Lang?
WCB Hitler's Hot Rod
« Reply #12 on: June 22, 2011, 12:32:54 pm »
You all fail! It's a WANG! Chinese knockoff of LANG.  Roll Eyes
« Last Edit: June 23, 2011, 06:19:50 am by wcb cal-look focker » Logged
« Reply #13 on: June 23, 2011, 06:04:35 am »
See the top corners in this drawing?  They dip down from the top deck.  Gary did this to clear the 4 corners of the engine case where the lower tin bolts on.  He did this to get the top deck of the sump as high and as close to the case as possible.  Those 4 corners of his sump were intended to be only 1-2mm from the case.  That way if the engine bottomed out, the corner of the sump would only deflect up by that small amount.  And that amount is not enough to cause the sump to break.  The mystery sump above doesn't have this unique feature.
Next look at the part of the sump directly below the engine case part line.  Again, the deck dips down to clear the bolts that hold the case together.  It gets the sump as high and close to the case as possible.
Go up and look at this mystery sump's mounting flange where it attaches to the case.  See how tall it is?  The designer of that sump didn't care how low it hung from the case.
In the 3rd pic above, you can clearly see how thick the mounting flange of the mystery sump is.  This requires longer studs, or special long nuts like Berg currently supplies.  Gary didn't go this way.  His flange was quite thin.  So thin that you didn't need any special hardware to attach his sump.  But a thin flange is no good, right?  Not a problem with the way a Lang sump fits so close to the case.
The fins on the top of a Lang are a lot shorter.  That's because it is so close to the case, they can't be nearly as tall as the ones above.
Have another look at the drawing of the Lang.  On the far side, you can see two of the fins on top have a short break in them.  This was to clear the bump on the case for the stud for the thermostat.
IMO it doesn't look anything like a Lang sump.
« Reply #14 on: June 23, 2011, 06:32:27 am »
JC Penny? Kiss
« Reply #15 on: June 23, 2011, 18:14:47 pm »
here's my empi , same mould at the lang sump
and check this tread and in this tread
another interesting tread with lang stuff , not sure that dean sump was a lang or another one who was mase in the same mould  as the lang sump like empi/dds/racetrim /treuhaft
« Last Edit: June 23, 2011, 18:18:46 pm by speedwell » Logged
Jos
« Reply #16 on: June 24, 2011, 01:21:24 am »
Is this the same sump as well? I've been searching for quite a while as to who manufactured this. I picked mine up for more like the price of a six pack of heineken  Grin
oilstain
« Reply #17 on: June 24, 2011, 01:54:23 am »
It's an early Scat!  Look at some of the early scat catalogs.
