September 10, 2026, 17:43:38 pm
Bad Habit
Type4 flywheel bolts
Topic: Type4 flywheel bolts (Read 16956 times)
Patte
June 21, 2011, 20:26:53 pm »
Is there anyone besides Ahnendorp who sells BAS flywheelbolts?
I need one set or two,they cost 69,90 Euros at Ahnendorp and that's reasonably fair price but they want 89,20 Euros in shipping for 5 bolts to Sweden
Thanx
Patrik.
http://bloggis.se/turbofastback
Re: Type4 flywheel bolts
June 21, 2011, 20:47:32 pm »
First off: thanks for a really nice event! Then secondly, did you read this:
http://cal-look.no/lounge/index.php/topic,14833.0.html
I know it isn't what you asked for but I do ask if BAS is needed or if they are any stronger than the ones you have been using.
Best rgs
Kalle
Patte
June 21, 2011, 21:22:55 pm »
Thanx for coming Kalle
I have read the topic and it is in line of what I'm thinking,but with the flywheel coming loose it kind of messes
with my head
12 years of racing type4 turbos and i never had this problem so now I'm looking in to diffrent options,maybe i will give the BMW ARP bolts a try.
//Patrik
max2919
June 21, 2011, 21:36:37 pm »
The new Turbo you have will mess with your head and every part in your engine....
VW 57 Ghia RLR 2919cc TURBO!
Porsche 356A Coupe replika.
RMS Boxer Service
June 21, 2011, 21:43:03 pm »
Hi Patte
I think I have a spare set in stock, I'll check tomorrow.
Rolf, DK
Patte
June 22, 2011, 20:38:13 pm »
Quote from: max2919 on June 21, 2011, 21:36:37 pm
True that
Patte
June 22, 2011, 20:41:33 pm »
Quote from: Callook_67 on June 21, 2011, 21:43:03 pm
Hi Patte
Rolf, DK
Thanks Rolf, but i have decided not to use the BAS bolts
RMS Boxer Service
June 22, 2011, 22:25:03 pm »
Quote from: Patte on June 22, 2011, 20:41:33 pm
Hi Patte
Rolf, DK
OK, but I do have a spare set if you change your mind.
/Rolf
June 23, 2011, 11:24:46 am »
Hi Patte
Rolf, DK
What way
are
you going Patte?
Patte
June 23, 2011, 15:41:35 pm »
[/quote]
/Rolf
[/quote]
Thanks, ill keep that in mind
Patte
June 23, 2011, 16:22:27 pm »
Quote from: JHU on June 23, 2011, 11:24:46 am
Hi Patte
Rolf, DK
What way
are
you going Patte?
I have decided to use Volvo V70 auto flexplate bolts(12.9 grade) and after discussing with
my friend Roland Erkki(AKA Rolando Furioso,AKA Rulle) who works at ABB robotics testlab he asked
the experts at clampingforce and friction what they would recommend in this case.
There is some kind of material that are 0,10 mm thick with diamonddust on it that is used as washers
when you wanna increase friction (100% more), to be used between crank and flywheel
but it seems to be hard to get.
More realistic is sandblasting the surface on the crank and have a polished surface on the flywheel
this will add 50% more friction.
As i have 5 dowels (6mm) already i will use them
/Patrik
June 23, 2011, 16:41:59 pm »
Quote from: Patte on June 23, 2011, 16:22:27 pm
Hi Patte
Rolf, DK
What way
are
you going Patte?
/Patrik
Patte, will you sandblast or mediablast (glass)??
Is there a partnumber for the Volvo bolts ?
Harry
Patte
June 23, 2011, 16:55:30 pm »
[/quote]
Harry
[/quote]
I think i will use aluminiumsilicat to get a rough surface.
Will try to get the partnr next week,everything is closed for midsummer celebration now
I think i hear a beer calling my name in the fridge,better respond to that holler i hear
Patte
June 28, 2011, 17:10:39 pm »
I was misinformed about the Volvo bolts,they are actually M11
So I'm going with these instead partnr 201-2801
http://www.importperformanceparts.net/imports/arpflyboltkits-all.html
Ill think they will be as good as it gets
Patrik
June 28, 2011, 20:55:11 pm »
The best way is to use 5 8mm Gene Berg pins and BAS bolts . That is for shure . 6 mm pins and stretch bolts will not hold up what you need
www.Udobeckertuning.de
June 29, 2011, 08:59:06 am »
Haven't you just snapped a set of BAS bolts Patte?
There is just one cure for this, higher clamping force. Better material in the bolt allows more tightening.
Any good bolt works in the way that you stretch it like a spring, if it doesn't allow stretching it's not putting in enough safety margins in the assembly.
What do the boys at ABB say about this?
Roland.E
June 29, 2011, 23:10:05 pm »
Quote from: JHU on June 29, 2011, 08:59:06 am
The longer the bolt is the more it stretch and by that gives a better safety margin to retain the preload even if something in the assembly seats together.
In my opinion by looking at the BAS bolts you can see that the part that can stretch is very short and therefore has a low safety margin for seating.
As you say the real solution is to have as good material as possible in the bolt and torque it as close to "permanent" stretch as possible=Max clamping force.
ARP 200,000 psi bolts have a "brake strenght" of 1378N/mm2 compared to a 12.9 bolt that has 1200N/mm2.
We have done some testing whith different surface finishes both in gears crimped on shafts and parts that are bolted toghether and the results always point in the same direction and the difference can be huge!
Last Edit: June 30, 2011, 14:17:25 pm by Roland.E
Juggas
August 05, 2011, 11:40:25 am »
Hi
What kind of torque have you used for the BAS bolts and other bolts?
/Juggas
October 22, 2013, 13:38:19 pm »
Ahh Per Johan, now I know why you asked Jakob Spring on Get Back on Track.
I googled and found this interesting topic.
Udo, I rate your knowledge high on TIV experience. Now I have been very hesitant to drill 8 mm pins in the TIV crank.
It does not leave a lot of material.
6 mm would be the way for me but so far, no engine I have built has anay pins. Not that many but a lot of years of abuse.
My Okrasa 82 mm since 1975 is still being raced.....no pins.
Maybe not as much starin as 10 second drag race starts and that is why.
So you recommend 8 mm and have good experience with it. No critisism. I am listening.
Some of my cars:
