October 15, 2026, 01:45:51 am
Oil Preasure question..
Topic: Oil Preasure question.. (Read 6078 times)
71CALRIPPER
June 22, 2011, 12:47:13 pm »
Guys quick question on oil preasure, took the motor for a spin last night but noticed the Idiot light flickers on idle, but the VDO guage stays happy at around 45 psi at idle and rises as she goes up the revs...! Anything to be worried about or check?
Motor is :
2276
9.5:1 compression with an external oil cooler , deep sump and fan..
glenn
Re: Oil Preasure question..
June 22, 2011, 12:51:41 pm »
45 PSI @ idle? I that hot or cold? What weight oil are you using?
Glenn
74 Beetle Specs
74 Beetle Restoration
2180cc Engine
www.DasVolks.com
Long Island's Aircooled Club
71CALRIPPER
June 22, 2011, 13:33:41 pm »
40-45 after a run but not hard one..! Not sure about the oil as I havent done the oil change yet..what would you recomend?
Thank you
Rob
John Rayburn
June 22, 2011, 13:58:06 pm »
Check it at the case with a mechanical gauge.
I also park at Nick's.
71CALRIPPER
June 22, 2011, 14:42:43 pm »
good the speedo oil light be to sensitive ?
John Rayburn
June 22, 2011, 14:54:25 pm »
You'll know if you check it with a mechanical gauge.
71CALRIPPER
June 22, 2011, 14:55:00 pm »
Thank you sorry I did read that the first time, just dont have one to hand lol
John Rayburn
June 22, 2011, 14:57:54 pm »
They're cheap and most places carry them. Do it now, so you know if something is wrong instead of running around town with bad pressure.
bugnut68
June 22, 2011, 17:44:23 pm »
Rule of thumb I've always been told is 10 PSI per 1,000 RPM.
June 22, 2011, 18:17:44 pm »
The light flickering at idle is a kinda of a norm when the engine is at temp --
The BEST oil that I've found recently is Mobil1 synethic for V-twins either the 10-40 (cool weather) or the 20-50 (hot weather) -- both have the ZDDP (Zinc for the lifters) in the 15,000 to 18,000 range -- they are about $7.50 a quart
http://selvedgeyard.com/
