October 13, 2026, 04:56:53 am
| | |-+  Pauter rockers and valve covers
Author Topic: Pauter rockers and valve covers  (Read 9050 times)
« on: June 25, 2011, 15:28:30 pm »
Hi all!
I'm running pauter 1.4 rockers with my 86c (043 heads) and stock valve covers. The rockers are hitting the valve covers and thus creating a leak (heavily).
I want to run other valve covers because of this and looked at the ones of CSP which seem very nice. As the Pauter rockers came with special bolts and studs I was wondering if the CSP valve covers hardware fits this. I expect the CSP hardware to be metric and the Pauter hardware to be imperial.
Any ideas?
Thanks!
Jesse
DKK Robert
« Reply #1 on: June 25, 2011, 15:40:37 pm »
Scat has a set that are made for high lift rockers and they fit just like stock valve covers,the  part # is 80240T.
These are what I will be trying on my new motor.
« Last Edit: June 25, 2011, 15:44:48 pm by DKK Robert » Logged
Type1/DVK
« Reply #2 on: June 25, 2011, 15:45:04 pm »
Paulus has the pauter rockers and orange csp covers. Works fine.
Can't you put some dents in them as temp. solution? as where they're hitting em.
« Reply #3 on: June 25, 2011, 16:35:33 pm »
Berg also have stock vented valve covers for ratio-rockers.
« Last Edit: June 25, 2011, 16:37:11 pm by Nico86 » Logged
« Reply #4 on: June 25, 2011, 17:14:07 pm »
I think he's gonna borrow/swap some SCAT valve covers, looks like the ones DKK Robert referred to:
hopefully all goes well!
jaqo
Bugster Team
« Reply #5 on: June 25, 2011, 18:17:01 pm »
I use them, they fit well and are leak free.
Stripped66
« Reply #6 on: June 25, 2011, 20:45:25 pm »
Is it the rockers or the mounting nuts that are hitting the valve-covers?
I had the mounting nuts hit the valve cover and prevent it from sealing (these were Scat cast aluminum valve covers). I removed about 1/4" from the length of each nut to clear.
« Last Edit: June 27, 2011, 11:57:39 am by Stripped66 » Logged
kingsburgphil
« Reply #7 on: June 26, 2011, 05:43:27 am »
My CB Perf C-channel valve covers are going in the shit can. They would probably work fine on a stocker, otherwise caveat emptor.
I going back to the stock covers with double gaskets, at least those didn't leak.
« Reply #8 on: June 26, 2011, 08:26:58 am »
this topic is about the clearance of valve covers, though sealing is an important issue too  Wink
drgouk
« Reply #9 on: June 26, 2011, 09:02:33 am »
I used Flat 4 valve covers on my engine with pauter rockers, same as the csp valve covers. Yes the pauter rockers come with 3/8 unf studs and nuts, I drilled my valve covers to take a 3/8 cap screw, I then spot faced the bolt hole for the oring, It works nice.
kingsburgphil
« Reply #10 on: June 26, 2011, 15:19:26 pm »
Oh, I forget to mention they're on Comp. E's with Berg rockers and K800's. The retainers are interfering with the gskts, so much for clearance.
« Reply #11 on: June 27, 2011, 07:42:29 am »
Jesse installed a pair of borrowed SCAT covers yesterday. All went well and they fit fine. Now he's gotta source his own SCAT valve covers before EBI  Wink
fredy66
« Reply #12 on: June 27, 2011, 13:23:19 pm »
jk have them
arabia slugs
« Reply #13 on: June 27, 2011, 13:33:22 pm »
JK?
fredy66
« Reply #14 on: June 27, 2011, 14:14:47 pm »
http://www.justkampers.com/shop/scat-rocker-covers-pair-stainless-steel-j14337.html
arabia slugs
« Reply #15 on: June 27, 2011, 14:23:49 pm »
I believe he meant that stacking two valve cover gaskets creates more clearance.
« Reply #16 on: June 27, 2011, 14:29:18 pm »
ah, sorry misunderstood that post then. that may have worked too!
« Reply #17 on: June 29, 2011, 22:49:54 pm »
I'm running a 86c but with 1.5 pauters -- I had clearence problems with the rockers hitting the pedestal -- you probably will not have that problem with the 1.4's but keep an eye out for it
I'd post a link to the thread I did on UAC but it got real ugly fast LOL
