October 14, 2026, 03:45:22 am
| | |-+  Velocity Stacks 48 ida
Author Topic: Velocity Stacks 48 ida  (Read 8275 times)
Dan Ahrendt
« on: June 26, 2011, 10:52:57 am »
Hi at all,
have questions about Velocity Stacks for 48 ida.
What are the best and fit without modifications under the hood ?
(I like the optics of the gene berg Velocity stacks)
Please help and post a pic if you have  Wink
Dan
« Reply #1 on: June 26, 2011, 13:43:23 pm »
Berg stacks will only fit under the lid if you use short manifolds.
Taylor
« Reply #2 on: June 26, 2011, 21:43:35 pm »
Stock Weber stacks fit the best and work the best
« Reply #3 on: June 26, 2011, 21:53:31 pm »
I'm running Jaycee stacks. These combined with the pro fuel inlets made my car 2 tenths quicker on the 1/4 mile.
12.1 to 11.9
Lee
John Maher
« Reply #4 on: June 27, 2011, 00:27:16 am »
Recently ran some back to back tests on a 2332cc engine fitted with 51IDAs, comparing stock velocity stacks against the larger style.
On the flowbench, the larger, more flared stacks flowed exactly the same cfm as the stockers. The test was carried out on a Comp Elim head, fitted with manifold, carb locked in WOT position and velocity stack in place.
For the second test I dynoed the engine with stock stacks, then did several pulls with the larger stacks. Zero difference.
John Maher
andy M.
« Reply #5 on: June 27, 2011, 06:42:33 am »
Spoil sport! Grin
L.B.C.R.
« Reply #6 on: June 27, 2011, 14:00:28 pm »
Maybe my driving just got better then Cheesy
dangerous
« Reply #7 on: June 27, 2011, 21:00:08 pm »
add to this, that the IDA jet stack will perform as the italians intended with their own stacks.
Dan Ahrendt
« Reply #8 on: July 04, 2011, 08:55:02 am »
Thanks for your answers and help  Wink
