October 15, 2026, 18:52:39 pm
| | |-+  Empi 5s Wheel protectors
Author Topic: Empi 5s Wheel protectors  (Read 10974 times)
Russell
« on: May 07, 2007, 19:11:57 pm »
Guys
With original empi 5s can some one tell me if they should have wheel savers like BRMs where the wheel studs passed through ?
If so anyone got a photo ?
Best Regards
Russell
jick
« Reply #1 on: May 07, 2007, 19:21:10 pm »
hi there Russell,
 i've heard conflicting views on this but i think that they didn't use the BRM or Empi8 style sleeves......the ball socket type of empi 5 obviously doesnt as they are designed to suit the original VW bolts.......i have the other style of empi 5, which have the large flat bolt hole....most people refer to these as the early type, but actually these were the porsche 356 type ...... they fit on those drums/studs perfectly....with no sleeves or whatever.
if you have the larger flat holed 356 type machine7 do a lug nut which is a perfect fit for them.....let me know if you need those and i'll give you the product code.
cheers...jick
« Last Edit: May 07, 2007, 22:29:38 pm by jick » Logged
« Reply #2 on: May 07, 2007, 19:21:31 pm »
on the pictures i found they all have cups allready drilled in the wheels. but my 8 spokes need protectors, just like BRM's.
maybe there were different castings... speedwell will help more for sure
« Reply #3 on: May 07, 2007, 20:22:35 pm »
russell it depend the model you have  Huh first(right model) or second (left model) watch the picture the difference is in the hole for the lug  Roll Eyes
Frank LUX
Back...Soon...hopefully!!!
« Reply #4 on: May 07, 2007, 20:28:43 pm »
This is How the Inserts look like...
Frank
« Last Edit: May 07, 2007, 20:31:02 pm by Frank LUX » Logged
« Reply #5 on: May 07, 2007, 20:35:06 pm »
first generation you can bolt the wheels with vw lug nut , second may be with those empi aftermarket lug nut Huh
Russell
« Reply #6 on: May 11, 2007, 15:46:56 pm »
This is my wheels and therefore need inserts ? anyone got any ?
Best Regards
Russell
« Reply #7 on: May 11, 2007, 16:14:38 pm »
give machine 7 a ring, I know they can provide them as speeny p got some for his.
benssp
www.callookvw.com
« Reply #8 on: May 11, 2007, 17:30:04 pm »
Look like straight forward mag nuts, call me on monday, i'll sort you out Wink
01273-495800
www.vwheritage.com  My Job
YMCA
« Reply #9 on: May 11, 2007, 17:35:33 pm »
01273-495800
standard mag lugs wont work they dont make a mag lugnut with a large enough shank the Holes in the wheel are much Bigger then the standard Mag Lugs you have to use the spacers see picture
benssp
www.callookvw.com
« Reply #10 on: May 11, 2007, 17:44:43 pm »
I've got spacers too Grin
YMCA
jick
« Reply #11 on: May 11, 2007, 18:05:52 pm »
...."if you have the larger flat holed 356 type machine7 do a lug nut which is a perfect fit for them....."
i have the same type of empi and the mag nuts that machine7 supplied me fit perfectly....no need for spacers/ sleeves etc.....
 ***item code..402.240.70 wheel nut, mag m12x1.5, 3/4"od, 12 flat washer....£2.75 each.***
these are nuts to be used with studs by the way.....
« Last Edit: May 11, 2007, 18:18:15 pm by jick » Logged
Russell
« Reply #12 on: May 12, 2007, 09:25:25 am »
Guys
thanks Ill call ben and M7 on Monday to see what is best thanks
Best Regards
Russell
