September 26, 2026, 02:13:05 am
| |-+  For sale!
| | |-+  Vw Turbo Street
Author Topic: Vw Turbo Street  (Read 6313 times)
Maroon Baboon
« on: July 05, 2011, 15:42:02 pm »
New inspected ready to run in really good condition.
Volkswagen 1302 -72
Sweden
20miles north from Stockholm
Approx 200hp
Price: 59 000: - SEK
Construction cost approximately 100,000 -
Has been featured in newspaper Volks World with a large repotage.
It comes with a helpärm with documentation, pictures and repotage
There are over 600 pictures to the person seriously and realize that to afford to buy this bee.
The car's Gävle
Feathers incl. using spring Sellholm Tuning
Top Storage VW 1303 -74
Shock absorber rear Cofap gas
Drop Stop Nedfjädringsstopp
Rear Wheel Mod. Typ3
Wheels 100 + DTM 16 "Bultdeln / aerating, Volvo 850
Front tires 205/45-16 "
Tyre, rear 205/55-16 "
New position for växelförararm Mod. Chassis
Color code for paint Scania Chassis Grey (darker shade)
Brakes
3.1 Description
Vented discs on all wheels with 1-piston sliding rear yoke which has integrated hand brake. 2-circuit brake system with front and rear circuit. Master cylinder from Volvo. Steel braided brake hoses all round. Welded to the spindle for the brake calipers.
 3.2 Replaced / Modified Components
Brake caliper front Volvo 850 Ate
Brake disc front Volvo 850 Ø280mm T = 26mm
Holder for front yoke milled steel plate welded in the spindle.
Brake calipers Rear Subaru Leone (front)
Brake disc rear Mod. Volvo 850 Ø280-275mm T = 26-21mm
Holder for rear yoke Aluminum 7075-T6 Bromssköldens attachment
Master cylinder Volvo 240 Ate (left utg References to 740 in regbevis)
Brake lamp switch M10x1
Drivetrain
4.1 Brief description
4vxl Porsche box provides the original drive shafts with the power that comes from a type 1 engine to 2276cc busy with overcharging. Volvo's large flange to the turbo. 9,3:1 in compression ratio, Ø94mm in drill and 82mm in kind.
 Engine No: AB383192, 1285cc, 33kW/44hk
4.2 Replaced / modified engine components
Engine Block Courage. AS from Brazil
Crankshaft Scat 82mm (cast) VW records, 8-pin
CB Performance connecting rods 5.600 "
Forged Pistons Mahle Ø94X82mm
Cylinders Mahle Ø94X82mm
Tops CB 044 Supermag (ported, 57cc incinerated. Room)
Top gasket 1.5 mm copper ring
Valves Stainless Steel 42/36
Valve springs Dual
Vipparmsfäste reinforced, bolted ends
Ventiljusterskruvar articulated with ball
Eagle Racing Camshaft 278 °
Cam followers Ultra LW (Lightweight)
Kamdrev CB Performance (straight-cut)
Building Description of modifications for the Volkswagen 1302 -72 (Street-Beetle)
Volkswagen 1302 -72 (Street-Beetle) GFR 184
Oil Pump Melling
Oil filter Optional V.A.G
Pushrods hardened Cromolly
Studs for peaks Cromolly
Stötstångsrör Eg. Mfr. Original packing suits
Pulley, engine Eg. Mfr. Steel 2kg
Belt 6PK1390
Belt 2pc Kamremspännare Golf type1
Pulley alternator / fan Eg. Mfr. Alu
Cooling fan 911 (11 sheets)
Cooling capacity Sune Jansson, Fiberglass
Exhaust, primary Eg. Mfr. Stir from GIK Turbo Technology
Turbo TD04-12 (Volvo V70, twisted house, courage wastegate shaft)
BMC Airfilter
Exhaust out Biltemarör, Simon sports dampers
Rear engine mount (Gene Berg) Stainless steel turnbuckle in the steel beam, boat, auto parts store.
 Intake Manifold Eg. Mfr. Alu
Intercooler modified 550X180X65 from CC-Racing
Throttle Volvo
Fuel injectors Bosch Blue 9186060 (Volvo V70 T5)
Fuel Rail Eg. Mfr. Alu
Plenary Eg. Mfr. Alu
O-ring plenary halves 1st Ø2mm 1st Ø1, 5mm L = 374.5 mm
O-ring on top 2pc Ø2mm L = 195.5
Throttle damper mount the Volvo V70 (plastic, female)
Throttle Cable Adjustment Volvo V70
Throttle inc. housing Ø1, 25mm L = approximately 3.1 m
Flywheel Relieved to 5kg, 8 pin
Oil coolers Nissan 300ZX
4.3 Replaced / Modified Components of the Transmission
Trans Axle Mod. 4vxl Porsche 901 (911 -68, courage Ed Hub)
Mod. Ed. Hub Adapter for Original shaft / hub
Lamell 4-puck sinter
Pressure plate Kennedy Stage II, 1200kg / 217 ft. Ib
Rear Gearbox Eg. Mfr. Alu-beam Hockey pucks bush
Front Gearbox Eg. Mfr. Steel beam. Motor Bracket / Urethane Puck
Ing. Gear mechanism Eg. Mfr. Alu
Gear mechanism Lever Set, backwards Volvo 850
 Modified by Joakim Piejko
4
Fuel System
5.1 Description
Original tank with surge protection, self-breeds modified (divisible Cabinet) high pressure pump, fuel filter before and after high-pressure pump. Braided fuel line on the pressure side, returned to the tank filler. Solid fuel pressure regulator on 3bar.
 5.2 Replaced elements
Fuel pump Bosch 0580254984 (12v 506289-13 cz)
Primary fuel filter?
Secondary Fuel Filter Volvo 740
Fuel Pressure Regulator Volvo 740
Electrical System
6.1 Description
A basic system with the most necessary functions which are then grown into a serious oversight on rat's nest of extra features, and a Prospark (ignition / injection) engine management system that includes intake temp sensor, engine temp sensor, trigger sensors and trottelpotensiometer. Main switch in the luggage, and delströmbrytare the dashboard. Fuse Boxes Flat hedges, round fuses on wires at a few positions. Battery Placement in your luggage.
 6.3 Components
Motor control Prospark Chip Version 6
Ignition Coil Prospark (Ford Focus, Mondeo, etc..)
Trottelpotensiometer Bosch
Temp Sensor 2pcs Included Prospark
Trigger sensor Included Prospark
Turbo pressure gauge Equs
Oil pressure gauge Equs
Oil coolers fan Engine room fan, boat, auto parts store 25-832
Oil coolers fan thermostat / relay Eg. Mfr. (Electronic thermostat cuts out when hot)
 Fusebox 2pc Universal, flat fuse
Headlights Crystal (Golf type2)
Flashers / lamp 5 / 21 W (in the bumpers, 5W not connected)
Starter VW 1600TL automatic
6.3 Components energized when the main power turned on
Brake Light
Light switch
Horn
Radiator Fan Control to oil coolers
Starter feed
Ignition Switch
Start Button Dashboard
Start Button Engine Room
Kupe'fläktomkopplare Not diverted
5
6.4 Components energized when ignition turned on
Motor control, including spreaders
Fuel pump can be disconnected via switch
Helljusomkopplare
Direction Selector
Wiper Mode Select
6.5 Components energized at the start position of ignition switch
Startmotorsolenoid
Bodywork
7.1 Description
Original Body, which shifted approximately 2.5 cm to the left of the rear mounts to get the wheel openings are symmetrical, and the anterior floor of the luggage is removed hijacked, rear part of the "floor" against the firewall is elevated approximately 20 cm, about 3.5-4cm wide plate screens around, and removable "between the sheets" rear. Bumpers from VW in 1303 -75, after which the lamps can be used for marker lights front and rear dimmljus when it sits dubbelpolslampor in brackets (5/21W). Running boards are moved 2.5 cm m.h.a. 25x25 tubes.
 7.2 Replacement / Modified Components
Mirrors Mod. Micro car parts with the original attachment
Front fender Mod. VW 1303 -75 (w / hung 3.5 cm)
Rear wing mod. VW 1302 (width approx: 4cm)
Front bumper incl. Mount VW 1303 -75
Rear bumper incl. Mount VW 1303 -75
Rear middle plate Mod. VW 1302
Color code for paint NCS.5502B Scania chassis (two comp truck paint)
Interior
8.1 Description
Pretty spartan interior with two race seats, cage, some carpet and a few instruments, recorded for a passenger.
 8.2 Components
Fullbur Missing a few tubes for racing regulations.
Chairs 2x Cobra Monaco, on adjustable base
Turbo pressure gauge Equs (mechanical / pneumatic)
Oil pressure gauge Equs (electronic)
Fire extinguisher 2kg powder
Seat belts 3-point CD Cardic (Meca Car Parts
Maroon Baboon
« Reply #1 on: July 10, 2011, 08:32:48 am »
Up
Roni
« Reply #2 on: August 04, 2013, 10:25:56 am »
What happened to this car? Sold?
Wish I had found this before, would had been the perfect car for my needs Smiley
Maroon Baboon
« Reply #3 on: August 04, 2013, 18:43:36 pm »
The car sold
