October 13, 2026, 10:09:51 am
| | |-+  DDS camshafts
Author Topic: DDS camshafts  (Read 8195 times)
BABOON
SCC Official
« on: July 14, 2011, 08:09:48 am »
Can someone please help with camshaft specs on some DDS camshafts?
136-S
141
141-D
« Reply #1 on: July 14, 2011, 08:40:44 am »
136-S:
Street & Off-road; excellent low-end response; 1500–2180cc; 280 degrees; 0.415in lift. Timing: Exhaust 70°/30° – Inlet 34°/66°
141:
'Not very streetable but good for the strip' (Deano's words!); large cc; 302 degrees; 0.443in lift
141-D:
Full competition grind; requires 1.4:1 rockers; 342 degrees; 0.500in lift; Timing: Exhaust 101°/71° – Inlet 65°/97°
Hope that helps... Smiley
BABOON
SCC Official
« Reply #2 on: July 14, 2011, 08:52:05 am »
That helps very much. Thanks
BABOON
SCC Official
« Reply #3 on: August 23, 2011, 10:31:50 am »
One more question.
My engine is based around:
82 SPG crank
88 Piston/sylinders (ccm 1995)
DDS 136-S camshaft
Original heads with 40/35.5mm valves (ported)
42 DCNF carbs
What kind of ratio rockers are suited for this engine? This will be a street/daily driver only.
dyno don
DGVA DZK (old school 70's)
« Reply #4 on: August 25, 2011, 19:45:49 pm »
 the most practical would be your stock 1:1 rockers with some good swivel style adjusters as the cam in question is a quite relative small cam designed for bottom end torque and good driveability. You could go to 1:25's also with good results as well providing you have some port work to take advantage of the extra lift.   good luck..!!
Frenchy Dehoux
« Reply #5 on: August 25, 2011, 21:18:00 pm »
      Dyno Don is the man he knows 42 DCNF.
     Frenchy
Doctor Detail ( Retired )
BABOON
SCC Official
« Reply #6 on: August 26, 2011, 09:23:49 am »
Very good. Thanks
51splitDLX
« Reply #7 on: September 15, 2012, 20:37:59 pm »
Any chance u have spec's on a DDS 146 grind cam Huh
I'm building a DDS motor and am exploring My options with available parts Huh
thanks in advance
kiefer
rick m
« Reply #8 on: September 19, 2012, 02:03:22 am »
You will love the 136S with that motor combo. Lots of great mid range power where you do most of your driving.
Rick M
Rick Mortensen
Driving Hot VWs since 1970
