October 05, 2026, 17:33:46 pm
352314 Posts in 28957 Topics by 6926 Members
Latest Member: Chakalives
| | |-+  magneto help please
Author Topic: magneto help please  (Read 9942 times)
Rocket Ron
It's old school for a reason
« on: July 15, 2011, 10:35:23 am »
Hi Guys
I tried installing my vertex magneto last night and came up against a few headaches that have me foxed
took out my 009 and slipped in the mag and connected the plug leads 1432 and no joy, then connected the leads 180 degrees out but as indicated on the cap that I thought must be wrong and it starts on the button,
completely back to front from the 009, timing light shows that it is firing on BDC, this cant be right ??
also where is the best place to ground out the kill switch. I had a autometer tachometer signal converter wired in as per the wiring diagram but this didn't kill the mag so had to pull the leads to get the engine to stop.
BTW I really couldn't believe it would run on one cylinder with a mag but it does  Shocked
Any help would be great or could someone point me towards any good reading on the subject, did a search but seems that there is little real information out there
Thanks inadvance
13.12 @ 101.84
Grooving out on life
Taylor
« Reply #1 on: July 15, 2011, 10:49:04 am »
If you take the caps off both the 009 and mag and point the rotor in the same direction, does the position of the slot on the bottom match or is it also 180 out of each other?  If so no biggie, might just have to remove and reinstall the drive also 180 out or change it on the mag.  Also what plug did you take the timing reading from?  No mater the position of the mag, if the motor is running, no. 1 and no. 3 will always fire on tdc and the opposite is true of no. 2 and no. 4.  Not sure if this helps    Taylor
Rocket Ron
« Reply #2 on: July 15, 2011, 11:32:53 am »
cheers taylor
I double check that tonight
where do you ground out the switch to kill the magneto
Regards Ron
13.12 @ 101.84
« Reply #3 on: July 15, 2011, 11:55:17 am »
Hi Ron,
No idea bout the kill switch, are you running any form of rev limiter?
Rocket Ron
« Reply #4 on: July 15, 2011, 12:30:23 pm »
Hi Ron,
no rev limiter lee
13.12 @ 101.84
andy M.
« Reply #5 on: July 15, 2011, 13:49:14 pm »
Run a wire from the terminal on the side of the mag to the dash and fit a toggle switch, connect the mag wire to one terminal on the switch and the other to earth anywhere you like, this will stop the engine, if you hide the switch under the dash away from prying eyes it will also double as a simple anti theft device
andy
L.B.C.R.
« Reply #6 on: July 15, 2011, 15:14:51 pm »
Hi Ron,
no rev limiter lee
I would fit one, if the mag is as good as ive heard and you miss a gear,linkage gets stuck open you don't want it grenading......
« Reply #7 on: July 15, 2011, 19:00:27 pm »
andy's right on the wiring and flick switch. a rev limiter is not a necessity. if you f*ck up, hit the switch and the engine's off instantly.
i still need to wire in my limiter, but i do have a joe hunt signal converter, same item as autometer sell. it works nicely!
btw, does your vertex have a curve or are you gonna run locked ignition?
Rocket Ron
« Reply #8 on: July 15, 2011, 19:41:13 pm »
Thanks  Andy, Lee and Diederick
Not sure if it locked or not as I bought it second hand
It is supposed to have a advance curve but we will see when it get the timing right
Ta Ron
13.12 @ 101.84
Rocket Ron
« Reply #9 on: July 16, 2011, 16:06:59 pm »
right
my mistake on 180 degree out timing as I must have put the timing wire on number 2 as I alway use number 1  Roll Eyes
the car is now running but no adavance curve so the mag is locked out, so what problems can I expect running it with 31-33 degrees advance, is starting the only bad side effect ?
I'm currently testing it on my 2275 8-1 compression ratio engine but it will go on my 2276 10-1  fk46 ultra wedge ports
final stupid question, can the mag be run with an alternator or a dynamo Huh?
Thanks in advance
13.12 @ 101.84
andy M.
« Reply #10 on: July 16, 2011, 16:17:10 pm »
you can only run a mag with a 356 12 volt dynamo.... not really, they really dont mind what you use, nothing at all is an option with a mag!
L.B.C.R.
Rocket Ron
« Reply #11 on: July 16, 2011, 17:19:20 pm »
funny you say that but that whats going on the new engine, but thanks  Wink
I was only checking as the live on the alternator seemed really warm, perhaps the bearings alternator on the way out then  Undecided
13.12 @ 101.84
« Reply #12 on: July 16, 2011, 21:12:33 pm »
perhaps it's time for a proper generator? what you need all those amps for anyhow?  Wink
Rocket Ron
« Reply #13 on: July 16, 2011, 22:47:13 pm »
not for my ignition now  Cheesy
Diederick you running your mag locked?, how many degrees advance ??
13.12 @ 101.84
