October 06, 2026, 06:24:16 am
Latest Member: Chakalives
| | |-+  Things that drive a guy batty...
Author Topic: Things that drive a guy batty...  (Read 4983 times)
bugnut68
« on: July 20, 2011, 18:11:08 pm »
I made the mistake of not feeding my throttle cable through before getting the engine fully installed... installed a new engine bay seal on the firewall side as well as surrounding the engine compartment, and now can't find the throttle cable tube to feed it through the shroud.  I've managed to feed a file through the tube and poke a hole in the rubber seal, but can't manage to get the cable fed through yet... it frayed so I cut the end off with the expectation of using one of those extender things to hook it up to the carb linkage, but have yet to find a way to get the cable fed through the rubber seal and the tube.  Driving me nuts.
« Reply #1 on: July 20, 2011, 18:25:16 pm »
i did this recently but didn't find any difficulties, what if you take out the generator including and backing plate and fan? 10 minute job, then you can put your hand through the shroud. should work like a charm. good luck!
bugnut68
« Reply #2 on: July 20, 2011, 18:31:16 pm »
Not sure I can easily do that with a doghouse shroud and all...If I get a brand new cable, I should (in theory, lol) be able to feed the cable through the hole I created in the rubber firewall seal and through the tube... finding the tube was a bit of a problem before I cut the end of the frayed cable off, as it missed the tube and went through the tin... or maybe I'll just have to pull my carbs off, unbolt the engine and pull it loose enough to feed the cable through.  Oi vey.
« Reply #3 on: July 20, 2011, 18:34:15 pm »
i did that with my doghouse shroud.
feeding the tube above the gearbox onto the tube that runs through the shroud is always a bit fiddly.
good luck  Smiley
Rick Sadler
« Reply #4 on: July 20, 2011, 18:48:01 pm »
Push a piece of welding rod through the throttle tube from the generator/alternator side of the fan shroud to to the top of the transaxle. Make sure you have a long piece of rod so that it still sticks out of the fan shroud. Butt the cable up to the welding rod and tape them together and pull the welding rod back out.  Wink
bugnut68
« Reply #5 on: July 20, 2011, 18:52:25 pm »
I'll try that again... I tried it using bailing wire/safety wire and electrical tape, but the tape kept coming off, lol.  I'll get at it again tomorrow night (I'm working this evening) when I have more patience.
« Reply #6 on: July 20, 2011, 21:44:44 pm »
Sounds like you don`t have the sleeve from the pan to back of the engine? Can`t you just do it from underneath?
bugnut68
« Reply #7 on: July 20, 2011, 22:12:55 pm »
Actually, I do have that... but it's been just hanging loose since I pulled the last engine... I think once I have a new throttle cable with the "big end" intact (the end that connects to the linkage), I should be able to fish it though the seal and the throttle cable tube.
