October 13, 2026, 04:59:29 am
Info on lightweight lifters with bushings
Topic: Info on lightweight lifters with bushings (Read 4143 times)
JIMP
July 23, 2011, 09:41:24 am »
Hello
was wondering if anyone has info on the lightweight lifters (slim body style with bushing) like the ones that remmele and engine plus sells. What I need to know
they are drilled as the std T1 lifters or they are undrilled and work kind of "dry" because of the bushing material?
Dimension of the body -diameter, length?
Diameter of the base -where it seats on the cam?
Usually they tend to be harder than the T1 lifters or more or less the same?
Hoping for your answers, chhers
Friendly
Dimitrios
Airspeed
Re: Info on lightweight lifters with bushings
July 31, 2011, 09:43:40 am »
I only can tell you that they are indeed drilled for oiling much like the stock lifters experience in the lifter bore
