September 01, 2026, 17:44:56 pm
oil pressure valves in the case...
5
Topic: oil pressure valves in the case... (Read 115592 times)
Re: oil pressure valves in the case...
Reply #90 on:
September 09, 2011, 17:29:05 pm »
Quote from: bugnut68 on September 09, 2011, 16:34:26 pm
Yup, if I have to ever stop for a cattle drive, I might get into trouble.
Lol. This car will at best be tooling around town on occasion or else primarily hitting our 1/8 mile strip, so I'm prepared to run what I gots for now.
I figure I'll try the other oil pump for giggles since it's not that hard to swap out, and I have the parts... figure can't hurt anything.
You haven't put the bigger pump in yet?! Do it already!
bugnut68
Reply #91 on:
September 09, 2011, 18:01:38 pm »
Quote from: Zach Gomulka on September 09, 2011, 17:29:05 pm
Well, not exactly... I installed 30mm Schadeck pump to find no change... next step is the cast iron one Jason L from VW Paradise sent my way. I woulda done it last night but had to work! Dang evening meetings...
Likely heading out there again this evening. I considered Wednesday night's session with the better mechanical gauge a success, as I at least know my oil pressure isn't starvingly low, so the engine is indeed operable.
Reply #92 on:
September 09, 2011, 18:21:14 pm »
Put that new pump and start having fun!
bugnut68
Reply #93 on:
September 09, 2011, 18:23:17 pm »
I'm more than ready for that last part!
Lol.
Speed-Randy
Reply #94 on:
September 10, 2011, 00:35:28 am »
Dude, just drive the thing. Worm has had the same problem since he bought the car. As long as the oil's moving you'll be alright, put an external cooler with a fan on it. It might runner a few degrees hotter than another engine, but whose to say the next one wont do the same thing.
www.vdubspeedshack.com
bugnut68
Reply #95 on:
September 10, 2011, 00:46:16 am »
That's where I'm at, pretty much. It's not like I really built this thing to be a highway hauler or 100K motor by any stretch. My goal is to fix a few leaks this weekend and finalize a few other details on the car before starting to put some miles on it.
bugnut68
Reply #96 on:
September 11, 2011, 02:40:05 am »
Annnnnnnnnd....... seized. Apparently. Awesome.
Swapped out the Schadeck 30mm pump for a Melling/cast iron pump (snug ass fit compared to the Schadecks, let me tell you what) today, and took the time to helicoil the four pump stud holes in the case as at least two were stripped. I wound up helicoiling them all for the hell of it since I was in there. Put everything back together, tried to fire it up and the starter clicks dully like one that cannot turn over a locked up sumbitching engine. Tried to turn it over by hand and only the crank pulley bolt turns; it ain't going anywhere. Tried to push it to see if the starter was locked up (before trying to turn it over by hand) and no dice. the car bounced but it would kick the engine over.
Must be a spun bearing in there, somehow, someway... don't know how it would have happened since the mains were all properly indexed (I'm very meticulous with these details during assembly, knowing I don't want to go back in there anytime soon after). Everything was fine in short block stage, still fine as the top end came together... but this would explain the low oil pressure if a bearing twisted somehow and blocked off oil flow.
Great weekend so far, all in all. Prior to working on the car I got word that my grandfather's health is rapidly declining (Alzheimers and lung cancer), so I'm heading over there tomorrow after covering a Sept. 11 memorial put on early in the morning by our local Veterans of Foreign Wars office.
Reply #97 on:
September 11, 2011, 03:53:07 am »
Since you changed the pump I'd be willing to bet you have zero pump to cam bolt clearance and that's why the engine isn't turning over.
Reply #98 on:
September 11, 2011, 08:01:57 am »
Quote from: bugnut68 on September 11, 2011, 02:40:05 am
No way. A bearing spins when the engine is running, and the engine loudly tells you it happens.
Something is wrong with the pump like Zach said.
bugnut68
Reply #99 on:
September 11, 2011, 17:20:47 pm »
I'm sure you guys are right... my head's in two other places right now, in family crisis mode and all, so I'm not necessarily thinking terribly logically.
Reply #100 on:
September 11, 2011, 20:01:59 pm »
Hang in there buddy.
bugnut68
Reply #101 on:
September 12, 2011, 16:31:39 pm »
Quote from: Zach Gomulka on September 11, 2011, 20:01:59 pm
Yeah, it's hard but I'm trying... my grandfather's not doing so well right now, hospice is now involved and things are getting pretty bad. Went to go visit him yesterday, and I'm glad I did as it's hard to say how much time he's got left, but I sure hope he doesn't suffer.
Reply #102 on:
September 12, 2011, 20:48:43 pm »
x2
So.Cal.Life
Reply #103 on:
September 15, 2011, 10:05:55 am »
X3 family is priority #1 KG
bugnut68
Reply #104 on:
September 15, 2011, 16:47:26 pm »
Just got a call from my mom last night, sounds like my grandfather is rapidly deteriorating.... hospice guesstimates 1 to 4 weeks left at this point. As strong as my grandfather was a for most of his life, I'm floored that this is what it's all come down to, ultimately.
Reply #105 on:
September 15, 2011, 18:17:05 pm »
It gets us all... when I go I hope hospice has nothing to do with it! I hope he's without pain. I lost my grand dad last October, I was thinking the same thing.
bugnut68
Reply #106 on:
September 15, 2011, 18:33:54 pm »
There's always been a VW in my family one way or the other... my grandfolks had a '55 Oval with semaphores they bought from my Dad way back when...lol.
It isn't easy either way... last night's foray into the shop was unsuccessful. Broke a pulley puller trying to get my pulley off and the rest of the night was spent trying to fix the tool.
bugnut68
Reply #107 on:
September 16, 2011, 17:13:05 pm »
Some progress being made... managed to get the pulley off and the cast iron pump is starting to come out after last night's efforts in the shop. I've all but killed my poor three engine builds-old oil pump puller in trying to get the pump out... she's a stubborn one.
So.Cal.Life
Reply #108 on:
September 17, 2011, 10:34:51 am »
Try loosening the case bolts above and below the oil pump opening, this eases the clamping force of the case on the oil pump , making the removal and installation of the oil pump easier.... just my experience KG
bugnut68
Reply #109 on:
September 19, 2011, 16:47:52 pm »
Quote from: So.Cal.Life on September 17, 2011, 10:34:51 am
Already did that... grandpa passed this weekend so it'll likely be a bit before I can get to it again.
Speed-Randy
Reply #110 on:
September 19, 2011, 17:51:57 pm »
I'm sorry to hear that
Reply #111 on:
September 19, 2011, 17:52:44 pm »
Sorry to hear that too Ryan.
bugnut68
Reply #112 on:
September 19, 2011, 21:52:26 pm »
Yeah, it's rough. Funeral service is on Wednesday, I may try to head out to the shop tonight for a little bit, see if I can get the pump all the way out... it's my buddy's shop and I don't want the car to be in his way. The loss in the family is all the more realized when you get together and visit with other relatives, as I did this past weekend. I can only imagine how my grandma must feel after nearly 65 years of living with the same person.
So.Cal.Life
Reply #113 on:
September 20, 2011, 00:41:08 am »
I'm sorry for you and you're family's loss, working on your car at a time like this is a healthy distraction from everything else going on, it has always worked for me. Ask you're grandma how shes feeling , coming from her grandson, I'm sure she will take it as a sign of interest and love, I'm sure.
Reply #114 on:
September 20, 2011, 00:53:32 am »
Quote from: bugnut68 on September 19, 2011, 16:47:52 pm
Sorry to hear of your grandfather's passing.
bugnut68
Reply #115 on:
September 20, 2011, 01:18:40 am »
Thanks, all, it's truly appreciated. My grandma has plenty of family around her right now. I was over there for the weekend visiting and will be going back for the funeral this week. I anticipate it will be a crowded house; he was a good man for sure.
I'll likely get out to the shop this week sometime... think I'm going to have to order a new puller tool, as my old one is all "taco'd" out... the pump is about 1/3 or 1/2 way out, but its a real tight fit, so I just have to keep at it.
Speed-Randy
Reply #116 on:
September 20, 2011, 04:24:41 am »
Quote from: bugnut68 on September 20, 2011, 01:18:40 am
pm your address, I'll send one up
Reply #117 on:
September 20, 2011, 05:19:58 am »
Sorry to hear about your grandpa Ryan.
Reply #118 on:
September 20, 2011, 08:39:42 am »
Warm up the case around the pump with a heat gun. The iron pump won't expand as much as the case, allowing you to simply pull it out with your hand (in a glove).
bugnut68
Reply #119 on:
September 20, 2011, 18:53:25 pm »
Quote from: Bruce on September 20, 2011, 08:39:42 am
Thanks, Bruce, I'll give it a whirl. I know Harbor Freight sells heat guns, but I'm guessing a hair dryer would do the trick as well?
5
