September 22, 2026, 01:30:31 am
| | |-+  Engine pull made easy !
Author Topic: Engine pull made easy !  (Read 8660 times)
Kaferdog
« on: August 07, 2011, 02:02:06 am »
Ok I saw that Lift at Sears and thought "Hey I have a idea"..after discussing it with My friend Ted we questioned it ..Then I could not stop thinking how perfect it would be  to pull a motor with..!!..Well it just so happened that my friend Dan had one for his Bike Happily lending it to me to try it out I did !!...Worked like a charm..!! no more hoping it does not tip or fall off that Jack pad !......I love it Running out to Sears to pick one up ...A.S.A.P....It's on sale for $179.99....!..Not bad in my book !
« Last Edit: August 07, 2011, 02:03:51 am by Kaferdog » Logged
Kaferdog
« Reply #1 on: August 07, 2011, 02:06:08 am »
More shots
Kaferdog
« Reply #2 on: August 07, 2011, 02:09:20 am »
Still more.....
« Reply #3 on: August 07, 2011, 02:09:36 am »
Very cool ! Just a thought, How about make something like that to replace the ring on a floor jack ?
Kaferdog
« Reply #4 on: August 07, 2011, 02:13:20 am »
"Exactly "Danny..I thought of that and "You" were the one I thought of !!!...But having the wider wheel base made sooo easy and stable !...It was rock solid !
« Reply #5 on: August 07, 2011, 02:33:09 am »
Ya , I have to admit that jack is bitchen !
Kaferdog
« Reply #6 on: August 07, 2011, 02:35:45 am »
It's very lightweight also...!
« Reply #7 on: August 07, 2011, 03:20:41 am »
Do you have a part number for the jack?
Kaferdog
« Reply #8 on: August 07, 2011, 03:23:59 am »
Here you go Donny
http://www.sears.com/shc/s/p_10153_12605_00950191000P?prdNo=4&blockNo=54&blockType=G54
Dan Mazur
« Reply #9 on: August 07, 2011, 05:29:23 am »
Glad it worked out. My Harley looks good on it too!
Don't worry.  It's mutual.
« Reply #10 on: August 07, 2011, 06:24:38 am »
Sounds like the hot ticket, I'm next in line to try it to swap out my motor with another. Looks like it makes life simpler.
Ted
« Reply #11 on: August 07, 2011, 12:02:45 pm »
VW thought about it  Wink
Plans where provided to dealers to build it.
A friend has a complete file with plans from a very old vw mechanics.
« Reply #12 on: August 07, 2011, 15:38:37 pm »
Time for fabbing.
Type1/DVK
« Reply #13 on: August 07, 2011, 19:22:14 pm »
i've got those doc's: here ya go.
Jesse/DVK
'64 2176cc
« Reply #14 on: August 07, 2011, 19:55:54 pm »
I just made something from wood that goes onto my own jack. Doesn't look as cool as the jack above though Cheesy
brian e
« Reply #15 on: August 08, 2011, 03:47:12 am »
This is what I use.  Sturdy enough to run an engine on when its lowered down.  Mine doesn't have the long strange handle though.
http://www.harborfreight.com/1500-lb-capacity-atv-motorcycle-lift-2792.html
Kaferdog
« Reply #16 on: August 08, 2011, 05:49:00 am »
yeah I saw that jack too.....should work the same but I'll go with the Craftsman jack....it's really light !
Kaferdog
« Reply #17 on: August 08, 2011, 05:52:40 am »
maybe we can Danny Gabbard to fab on of these up.....?....Maybe even one for bigger sumps..?....Hint,Hint.... Wink
