October 14, 2026, 14:10:05 pm
| |-+  For sale!
| | |-+  Original Empi Aluminum Biral 88mm's
Author Topic: Original Empi Aluminum Biral 88mm's  (Read 2838 times)
brian e
« on: August 11, 2011, 06:46:32 am »
Original vintage aluminum biral Empi/Mahle 88mm pistons and cylinders. These were used in a racer in the early 70's. Only three matched pistons and cylinders.  The last one dropped a valve and was tossed out years ago. The piston tops have a slight relief cut for the intakes. Cylinder walls look good, all pistons balanced, no broken fins.
$450
I also need the following for possible trades;
4 lug baby gasburners, Original or repop
Porsche patern gasburners, original or repop
Weber IDF's, 40mm-48mm
45 or 48 dell's
IDA's
New Mahle 94mm B's
New or DPR 78.4, 84mm crank
42x37 ported or 044 heads, cut for 94's
