September 12, 2026, 15:53:11 pm
352304 Posts in 28956 Topics by 6924 Members
Latest Member: Bad Habit
| | |-+  velocity stags
Author Topic: velocity stags  (Read 4656 times)
vintagewagenwerks
« on: August 11, 2011, 18:48:54 pm »
Is someone use velocity stags with out aircleaners in normal streetuse? I explained about doing this but i think it woll not good for the engine and carburators getting in all the dust .Can someone share his experience with this.
Itīs better to burn out than to fade away.
Jesus
« Reply #1 on: August 12, 2011, 07:24:27 am »
I haven't run air cleaners for years now and not had any issues but i think it's safer in a bus than a bug due to the way the air cirulates down the rear vents, the bigger bits end up sat in my battery trays rather than getting anywhere near the intake.
« Reply #2 on: August 12, 2011, 07:35:27 am »
Have you taken the engine apart and had a close look on your cylinder walls? If not, then I can understand why you do not use filters.
Jesse/DVK
'64 2176cc
« Reply #3 on: August 12, 2011, 08:59:08 am »
Why not use the foam type filter? You can take them off easily at a meeting to show those stacks Smiley
vintagewagenwerks
« Reply #4 on: August 12, 2011, 19:42:46 pm »
mhh .the dust destroys the cylinder and pistons maybe close the oil channels so i think when i read your replies
 Huh
