September 24, 2026, 02:58:26 am
Help with jetting IDAs for a 1776cc
Topic: Help with jetting IDAs for a 1776cc (Read 17025 times)
Oldschool
May 13, 2007, 16:19:09 pm »
As some of you may have seen in "What did you get in the mail today?", I just got a pair of IDA with missing parts though.
So I was wondering if any of you could help me sort out what jets, emulsion tubes, venturis... I should get knowing that I'd probably build a 1776cc in a while
I have 3x40mm venturis and 1x37mm venturi, 2 F10/70 emulsion tubes.
I need 2 auxiliary venturis, 4 accelerator fuel pumps...
I'll list the parts I need with their references later
Last thing, if you have addresses where I could get the missing parts I'd be more than thankful to you
Oldschool
Last Edit: May 13, 2007, 16:21:23 pm by Oldschool
Quality not Quantity...
Frank LUX
Back...Soon...hopefully!!!
Re: Help with jetting IDAs for a 1776cc
May 13, 2007, 16:24:12 pm »
Quote from: Oldschool on May 13, 2007, 16:19:09 pm
Oldschool
I really Hope you got these "Things" sorry bout that, really cheap otherwise it was not a good Idea at all to buy these Carbs...
Frank
Oldschool
May 13, 2007, 16:51:47 pm »
Is that so difficult to get these parts or what?
Oldschool
Frank LUX
May 13, 2007, 17:29:18 pm »
Quote from: Oldschool on May 13, 2007, 16:51:47 pm
Oldschool
No, i would call it expensive...
Frank
Andi/DFL
May 13, 2007, 17:31:12 pm »
I can tell you which jetting works good with my 1776cc:
main: 140
air: 120
idle: 70f10 (too big but works. will change to 55 or 60)
emulsion tubes: f11
venturis: 37 (smallest available. I'd like to have 32 or 35, maybe I get some fabricated some day)
check the floats and float levels. I've learned the hard way, that this is REALLY important. :-)
And I would get the third progression holes drilled, if they aren't there already.
http://www.dfl-vwclub.de
http://www.flickr.com/photos/andidfl/
http://www.andreasreinhold.com
Oldschool
May 13, 2007, 17:45:37 pm »
Nice one Andi, thanks, but any addresses/links I could get these parts from?
I've had a look on the Berg website and they got pretty much everything I need, but Frank scared me, hope he was just joking!
Were you Frank?
Oldschool
Andi/DFL
May 13, 2007, 17:50:24 pm »
in germany, you can get everythin at victor günther motorsport in cologne (expensive):
http://www.vgs-motorsport.de/sgs/home.html
but all the jets are also available from CSP.
Frank LUX
May 13, 2007, 18:57:49 pm »
Quote from: Oldschool on May 13, 2007, 17:45:37 pm
Were you Frank?
Oldschool
No...
Frank
48IDA66
May 13, 2007, 19:06:36 pm »
I have run my 1776cc for more than a year now summer and winter on this set up:
37 venturi
150 main
200 air
F7
60 idle
And its just running no problems at all!!,I have the 3 hole drillet.. All help to set up my IDAs came from SOB/DBR thanks buddy!!....
Last Edit: May 13, 2007, 19:10:48 pm by 48IDA66
Oldschool
May 13, 2007, 19:48:44 pm »
Quote from: Frank LUX on May 13, 2007, 18:57:49 pm
Were you Frank?
Oldschool
No...
Frank
no problem
Thanks 48IDA66 for your set up details
Oldschool
May 13, 2007, 22:05:35 pm »
Try this Company for the Parts you need !!!!
The #1 source for Weber Carbs, Conversions and Components.
The Low price High Quality Leader and FREE UPS Shipping on all Kits.
We will not be undersold on any NEW Weber Carb or Conversion.
WeberCarbs.com is the largest and oldest independant Weber Carb distrbutor in the USA. We have been in business since 1984 and we know Weber Carbs. We have the Best Prices and the Best Technical Expertise to help our customers get the most from their Carb purchase.
We have an excellent IN STOCK Inventory of 32/36 DGEV, DGV AND 38/38 Carbs and Conversions as well as the NEW Weber 34 DGEC carb conversions for immediate shipment as well and DCOE, IDF and 48 IDA carbs and conversions. While most of the other guys are complaining there are no carbs available we have what you need and in many cases will ship the same day you order. Come Inside and see for yourself. There is a wealth of Information on this site and you will get the best possible deal on your Weber Carb purchase.
Beware of the Imitators and Cheap Knock Off Look-Alike Carbs on the Market. We sell NEW Authorized REAL Weber Carbs and Conversions. Not the made in China knock-offs that you cannot get any support for.
FREE UPS GROUND SHIPPING* On all complete conversions or orders of 2 or more carbs or any parts order over $200.00..Parts orders over $200.00 does not include Single carburettor purchases.
*In the lower 48 States...Alaska, Hawaii, and International orders pay standard shipping rates.....
Top-End Performance
7452 Varna Ave
N.Hollywood CA 91605
(818)764-1901 (818)764-0155 fax
e-mail:
topend@racetep.com
Place an Order
Ordering and Return Policies
Last Edit: May 13, 2007, 22:08:18 pm by Shubee2 (DSK)
May 14, 2007, 02:47:21 am »
My old 1776 with a W125, welded 40 x 35.5 044s, 9.3:1, 1 5/8 header used a 135-140 main, 190-200 air, F7 e tubes, 55 idles and 37mm venturis at sea level. I tried some genuine Weber 34mm venturis but it liked the 37s more.
Svwerker
May 14, 2007, 12:58:00 pm »
I have run my 1776 with IDA for about 5 years now. Sofar I have tried 37 and 40 venturis and I liked 40 best, I also tried both F7 and F11 etubes and F11 works best for me.
With 37 venturis I run 155-160 main and with 40 160-165. Air was always 200 and idle 60.
Specs are W110, 40*35,5, 9,3:1 15/8. Best ET is 14,49/144 with a slippering clutch in a all steel super, 950 kg
Oldschool
May 14, 2007, 18:19:16 pm »
Thanks a lot guys, it helps me figure out what my future specs will be (cam, heads...)
I just need to get the missing parts I need but as Frank implied it might be a bit of a nightmare, anyway even if it takes tim I'll get those bits
kind regards
Oldschool
May 15, 2007, 18:28:21 pm »
One more source: ACE Enterprises, Art Thraen !!!
Oldschool
May 15, 2007, 18:45:41 pm »
Thanks to all of you for your help and the links, I hope I'll get what I need with all that
Best R.
Oldschool
Oldschool
May 17, 2007, 09:32:12 am »
Last question what size do I need for the pump valve? Help me please
Oldschool
48IDA66
May 17, 2007, 14:00:06 pm »
200-250...
Oldschool
May 17, 2007, 14:03:16 pm »
Quote from: 48IDA66 on May 17, 2007, 14:00:06 pm
200-250...
Thanks 48IDA66
I guess I'll have to order soon thanks to your answers, the list is building up nicely
Regards
Oldschool
Oldschool
May 22, 2007, 13:47:50 pm »
200-250...
I've often seen size 50 for pump valves, is it too small or is 200-250 too big or adapted to a 1776cc engine?
I really don't know what to order
Regards
Oldschool
May 22, 2007, 14:14:46 pm »
Hi Old School are you talking about the Pump jets? that dump the Gas Size 50 or 55 are fine
Oldschool
May 22, 2007, 15:29:11 pm »
Quote from: Shubee2 (DSK) on May 22, 2007, 14:14:46 pm
That's what I'm talking about, thanks a lot Shubee2, I'll order them ASAP then
Thanks again
Regards
Oldschool
48IDA66
May 22, 2007, 16:05:02 pm »
200-250...
Sorry my mistake, I was thinking needle valve....
Oldschool
May 22, 2007, 18:22:21 pm »
Quote from: 48IDA66 on May 22, 2007, 16:05:02 pm
200-250...
No problem, it's all sorted out now
Regards
Oldschool
