September 23, 2026, 00:58:47 am
| |-+  Wanted
| | |-+  94mm Mahle stroker pistons required
Author Topic: 94mm Mahle stroker pistons required  (Read 4209 times)
Shane Noone
« on: August 24, 2011, 19:37:26 pm »
Hi guys does anyone have either a complete set preferably new and unused but would consider low mileage 94mm Mahle stroker pistons ( B ) OR even just one or two from used maybe from motor that has holed a piston or broke a wrist pin mount etc ? Need some fairly urgently to replace damaged on my 2332.
I am in England so looking for same for supply please.
Cheers,Shane.
james wotton
« Reply #1 on: August 24, 2011, 22:16:58 pm »
i've got some.
i'll pm my number over.
9.91 @ 139.90
outlawflatfour 2010 and 2011 champion.
Shane Noone
« Reply #2 on: August 25, 2011, 09:29:19 am »
Ok thanks James.Have picked up your number and will be in touch soon.
tonybone
« Reply #3 on: August 31, 2011, 12:10:23 pm »
Good luck buddy, hope the motor gets bolted back together soon.
Shane Noone
« Reply #4 on: September 06, 2011, 11:26:28 am »
Hi Tony hope your Singapore Sling went ok  Wink
John emailed me yesterday to say he has the motor all bolted up with the piston kindly provided by James and he was hoping to get it back on the dyno either last night or this morning to do some test pulls and make sure everything is running as it should etc and with any luck crate it up and have it back on the road to me by the end of this week fingers crossed.Once I get her back and in the bug want to get some road miles on her check for gremlins and with any luck run her at the track first weekend in October.
