October 14, 2026, 11:43:19 am
| | |-+  CB Roto Hubs, handbrake/ e brake issues?
Author Topic: CB Roto Hubs, handbrake/ e brake issues?  (Read 3719 times)
Deanodynosaurs
« on: August 30, 2011, 10:06:22 am »
Hi all,
I've fitted some CB roto hubs on the rear of my 58, and i'm having some issues.
I've tried to adjust the handbrake up at the nuts on the handle, but even though the mechanism at the back works (the cable pulls and spring compresses) the pads dont bite on the disk?  Huh
However, I havent actually fill and bleed the system yet. Just wondered if the anyone knew if the handbrake is haudralic too? Or is there something wrong with the kit?
I've included a photo if a rear brake caliper in case it helps.
Cheers as ever in advance.
Dude  Cool
jaqo
Bugster Team
« Reply #1 on: August 30, 2011, 12:50:52 pm »
In some types of modern calipers (like those probably) you have to use a normal brake few times in order to adjust the auto adjusters for the handbrake. Handbrake is mechanical but since you never used the main brakes, brake pads and pistons are not in correct working position. Fill it up, bleed it, press the pedal few times and it should work
Dominick Luppino
« Reply #2 on: August 30, 2011, 16:02:25 pm »
X2
61ragtop
« Reply #3 on: August 31, 2011, 15:00:42 pm »
X2
x3 the hydralics will naturally set the pistons closer, then the cable will work fine, had the same on mine Smiley
cheers james
