November 04, 2026, 07:20:31 am
| | |-+  whats better brake kit?
Author Topic: whats better brake kit?  (Read 4353 times)
beetletom
« on: August 30, 2011, 15:32:29 pm »
i'm after a wide 5 ball joint disc brake kit
who makes the better one?
csp or cb performance?
i would like to use them with dropped spindles for disc brakes
Speed-Randy
« Reply #1 on: August 30, 2011, 20:32:37 pm »
It's all in the caliper. If it's one of the stock looking calipers(gold in color), then it's basicly the same as any other brake kit. They are buying them from the same supplier and repackaging with there brand on it, the rotors might have a little different machine work on the mounting surface, but it's still a 5/205 using the same size bearings and the spindle probably needs to run a late tie rod end. If you can, use a kit that utilizes the wilwood calipers, those are nice kits
Speed-Randy
« Reply #2 on: August 30, 2011, 20:51:21 pm »
For the record, I've had the 5/205 dropped spindle Empi kit on my bug for the last five years trouble free, works great. I put the Neal 5/205 kit on my notch 10 years ago( non drop) with wilwood calipers and that worked great as well. So really the decision is how much do you want to spend
dannyboy
« Reply #3 on: August 31, 2011, 16:23:15 pm »
i had  a set of  airkweld bad billet fronts with willwood 4 pots and it seemed like a good setup the main advantage for me was my tendancy to change wheels often Roll Eyes
and the bad billet ones have interchangable hubs nut never heard a bad thing about csp ones or neal   Smiley
8.77@156.8mph
O/FF 60
« Reply #4 on: August 31, 2011, 17:13:56 pm »
I second the Airkewld units ... really dig being able to change bolt patterns! Only takes an hour or two and your rolling down the road.
