September 24, 2026, 21:39:38 pm
Drag Radials, Wheels, Fast Fab, MSD, Performance Engine Parts,etc condensed ad
Topic: Drag Radials, Wheels, Fast Fab, MSD, Performance Engine Parts,etc condensed ad (Read 7434 times)
Jo Clifford
September 01, 2011, 20:28:20 pm »
Linelocks - Hurst Roll Control/Linelock
Rear Ercos, Wide 5, 5 3/4" wide, used, perfect for short axle car
M&H Slicks 26/6/15
Fast Fab Breather boxes with -8 fittings
Fast Fab breather boxes with push on fittings
Fast Fab Fuel Pump Block off
Fast Fab Set of Push Rod tubes (Red, Silver and Black still available)
Fast Fab Hex T’Bars (set of 4)
Fast Fab round T bars (set of 4)
Fast Fab Radio Delete Plate with or without trim holes
Fast Fab Tach mount (Autometer) '65 to '67 (no drilling)
Fast Fab Race oil filler tower,red
Fast Fab Bottom deck lid stand off kit
Fast Fab Billet oil filter mount (Black, Silver, Blue and Red available)
New - MSD Blaster 2 Coil
New - MSD 6AL
Scat Chromoly stroker crankshafts 78.8mm & 82mm strokes, both VW rod journal,
84mm stroke with chevy journal new in boxes
Scat H' Beam rods, 5.4, 5.5 & 5.7
Scat sumps both 1.5 and 2 quart
Magnesium Rimco case, bored for 94's stroker clearanced, full flow, with shuffle pins on centre main, new
Mahle 90.5 piston & cylinders for 69mm stroke
94mm Total Seal 2nd rings
Manton Chromoly Pushrods 0.058 & 0.035 wall thickness, cut to length
Kennedy clutch covers, Stage 1
Kennedy clutch covers Stage 2
Super daikin clutch discs
26mm Shadeck Oil Pump
Engle Cams lots of different grinds available, including FK42, 44, 46, 8, 87, 89
(these are pre-clearanced cams, will not need clearancing up 86 stroke)
Scat Chromoly Gland nuts 36mm (not the usual 38mm)
Berg oil pump covers
Scat 8mm Chromoly head studs
Scat stainless valve covers with tabs,
Scat cam followers, both regular lightweight and lub a lobe available
Raw Merged Dual Mufflers
Genuine Empi Sprintstars 4 x 4.5 in nice condition, genuine caps, complete with tyres
Slot Mags, 4 lug, 2 off 4.5 US Indy Mags, 3 off 5.5 Shelby Cal 500,
very similar style wheels, would make a good set.
Riviera replicas x 2
65 cabrio decklid, the real thing complete with rain trays, not perfect, couple of dents and slightly bent but good solid version
NEW Simpson Harnesses
Simpson 62" Belt Pull-up, Bolt In, Camlock - Code 29104 - Black
Simpson 55" Belt Pull-Down, Bolt In, Latch/Link - Code 29063 - Black
Will be at Das Drag Day, so can deliver there.
Last Edit: February 08, 2012, 21:00:29 pm by Jo Clifford
https://linktr.ee/Redheadautoupholstery?utm_source=linktree_profile_share
http://www.rjvolksperformance.com/
Living the dream, not just talking about it ;o)
"Don't talk, just bring it" - Hector Urias
Jo Clifford
Re: Drag Radials, Wheels, Fast Fab, MSD, Performance Engine Parts,etc condensed ad
September 11, 2011, 09:12:04 am »
Decklid pictures
christ4
September 11, 2011, 12:42:04 pm »
you have pm!
Jo Clifford
September 18, 2011, 11:49:04 am »
Wheels pics
Jo Clifford
September 18, 2011, 11:54:20 am »
Fast Fab Pics
Jo Clifford
September 18, 2011, 11:57:31 am »
Wednesday (21st) is the last chance to order for delivery to Das Drag Day
Jo
Jo Clifford
September 18, 2011, 14:12:38 pm »
M & H Drag Radials **NEW**
Last Edit: September 18, 2011, 14:15:42 pm by Jo Clifford
henk
February 08, 2012, 20:46:23 pm »
hallo Jo,
just a little thank you,for sending al my parts and the help.
henk!!!
