June 10, 2026, 02:08:27 am
Latest Member: mvptkfjb
| | |-+  web cam 251
Author Topic: web cam 251  (Read 5695 times)
Robban
« on: September 05, 2011, 09:21:55 am »
I´m building a new t1 drag engine this winter, and i thinking of using the web cam 251, does anyone úsing it, or have any experience wiht it?
The engine spec:
2332cc, CR 13,4:1
5,5" rods, C/E 48/38 heads with stainles valves and K800 springs.
DER BRÜCKENRENNERS
Rasser
« Reply #1 on: September 05, 2011, 18:25:34 pm »
<a href="http://www.youtube.com/v/SYDU_X3mt_s" target="_blank">http://www.youtube.com/v/SYDU_X3mt_s</a>    web251  Wink
1955 type1
1966 type2 13w deluxe
« Reply #2 on: September 12, 2011, 11:08:05 am »
Hello.
If your engine is going to be all drag, I would consider a regular Fk89 or the CB version. The Web 251 seems to be a hairswith lower than the Fk89. But if it was for a semi street car I would take the 251, as it is somewhat more usable in the lower rpm and also idles nicer than the 89.
Robban
« Reply #3 on: September 13, 2011, 20:21:01 pm »
                              Fk 89     web 251
Valve lift 1.4:1          .582          .630
Cam lift                    .416         .450
Adverticed Duration   328*         324*
Duration @ 0.50        282*         285*
Lobe Center              108*        108*
DER BRÜCKENRENNERS
« Reply #4 on: September 14, 2011, 01:08:11 am »
The 0,630" on the Web is @ 1,5 ratio.
Like I wrote earlier. if you want to go all out  in that range, try the CB version.
neil68
« Reply #5 on: September 14, 2011, 02:26:03 am »
I have a Web 251 in my current 2332 cc and it measured out to 0.590" with 1.4 rockers (cam comparison chart says 0.421" at cam and 0.588" with 1.4's).
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Deadly1
« Reply #6 on: September 25, 2011, 20:45:54 pm »
Cam specs show Webcam 251 to have a little more lift than Engle FK89, slightly less "advertised" duration and slightly more actual duration at .050 lift. In my motor with Berg "so called" 1.45 rockers I measure almost .660" lift. Car ran 10.44 @ 127 -1575lbs. Wayne
