September 22, 2026, 21:24:59 pm
| | |-+  Anyone used Bugpack Street Elimintor heads?
Author Topic: Anyone used Bugpack Street Elimintor heads?  (Read 4980 times)
« on: September 07, 2011, 16:11:32 pm »
As title, they appear very similar to the CB Street elimintors (same?)
Are they a good head? Building a 82x90.5 K8 cam motor
Lee
hector
« Reply #1 on: September 08, 2011, 20:30:29 pm »
yup si's got a pair on his 1776 i built a few years ago , 130 cam ,ida's. the things a little ripper !
outlawflatfour.com farmers division
« Reply #2 on: September 09, 2011, 13:54:21 pm »
Thanks,
How's things with you/bug?
Lee
dyno don
DGVA DZK (old school 70's)
« Reply #3 on: September 11, 2011, 17:16:50 pm »
Hi Lee, I know of several guys running the Bugpack S/E  heads and no problems..if you have a head porter?...you can reprofile the heads and make more use of the port design to increase the port "velocity "as well of improving the cooling of the fin area.  As with most all aftermarket non vw oem castings they will tend to run somewhat "warmer" but with a good build and proper cooling....no worries.   good luck, Dyno
