October 14, 2026, 23:02:10 pm
Transaxle rear mount bolt hole dimensions / distances?
Topic: Transaxle rear mount bolt hole dimensions / distances? (Read 15587 times)
-Alex-
September 12, 2011, 19:59:06 pm »
Hello, i have lost old transaxle rear mount piece, and i need dimensions / distances for rubbermount bolt holes. Anyone please?
In my pic they are 139mm ans 117mm..
Last Edit: September 12, 2011, 20:45:08 pm by -Alex-
While Cal-Look stands still, looking backwards for inspiration, German Look keeps pushing boundaries further forward
Re: Transaxle rear mount bolt hole dimensions / distances?
September 12, 2011, 20:24:25 pm »
I just measured one in my garage and it appears to be 300 mm between the two large bolt holes. I measured it in inches, but on converting it to mm it was right there within a couple of thousandths of a millimeter.
-Alex-
September 12, 2011, 20:35:48 pm »
Thanks, 300mm is correct, but that measurement i have already and also the shape of the mount. I need bolt hole distances for original rubber mounts, on my picture they are 139mm and 117mm.
Last Edit: September 12, 2011, 20:48:00 pm by -Alex-
September 12, 2011, 21:21:05 pm »
The 139mm should be about 203mm and the 117mm should be about 109mm. Remember I measured these in inches then converted them to metric. My conversion program is pretty good, but I may not be...LOL!
-Alex-
September 12, 2011, 21:25:02 pm »
Are distances straight from center to center?
Last Edit: September 12, 2011, 21:54:24 pm by -Alex-
September 12, 2011, 22:08:03 pm »
I don't want to confuse anyone, but I measured with a rule and got:
117 = 105mm measured straight across and 139 = 175mm
Hope it helps more than hurts.
TxT
-Alex-
September 12, 2011, 22:12:49 pm »
Ok, thanks. This sounds better
Shape is perfect, but i forgot to measure rubbermount bolt holes. One guy wants this kind heavy duty rear mount, maybe from 6mm steel
Last Edit: September 12, 2011, 22:18:45 pm by -Alex-
September 12, 2011, 22:39:13 pm »
Remember the rubber mount holes are slotted.
September 12, 2011, 23:04:13 pm »
All of my measurements are center to center as best as I could.
-Alex-
September 13, 2011, 06:45:39 am »
Yes, thank you both
Yes, i did make the holes slotted.
September 13, 2011, 12:28:31 pm »
Quote from: Donny B. on September 12, 2011, 23:04:13 pm
You and me both Donny.
Hard to get a perfectly accurate measurement ...
-Alex-
September 13, 2011, 19:50:18 pm »
Well, holes are big, and he can make them bit larger perhaps
